Which heads for TR230, PRC LS6 or 5.3?
Wanting to add heads to my combo, and was looking at the PRC offerings. Question is, which ones would better compliment this cam? The stage 2.5 5.3, or the LS6 heads? Also, how much could I mill them? I will also be adding a Racetronix pump/hot wire kit and FIC 36-pound injectors, and most likely going back to a Yank PT4400 converter. Just wanting to mix things up a little and add some power. Thanks for any inputs...
LS6 Castings all the way. I never have been a fan of the 5.3s. Here's a set I had done:
https://ls1tech.com/forums/generatio...-cnc-work.html
I'm not against the 5.3s, but they are not as good of a casting design to my understanding. They do make slightly more compression but with slightly smaller valves. Maybe A.I. can work their magic and make them perform but I think an equally done 243 will perform better. Plus I have seen/read/heard of lots of cars that run mediocre times with CNC'd 5.3s, so I just kinda steer clear. But understand I'm not saying they won't perform, it's just I haven't really been impressed overall.
