New LS1 Owners - Newbie Tech - Tuning to minimize cam idle loop?
aznbadboixx
04-15-2012, 01:03 AM
I just bought a rx7 with a ls1 in it and it has heads/ cams / headers. I dont know the spec of the cam but its a little too loopy for my taste. I was wondering if getting the car retune can make it less loopy. Or would I need to replace the cam entirely. It rocks the whole car back and forth lol.
battousai
04-15-2012, 01:05 AM
raise the idle and it will hide the lope
aznbadboixx
04-15-2012, 01:22 AM
how high should I go. It idles around 1k right now. I think I'm going to need a retune anyway because sometime it would stall when I come to a light. Or the rpm drops down to like 100 and jumps back up to normal. Now I read up some post saying that I shouldn't mess with the idle screw and I should get it the idle tune in. Is it safe for me to mess with the idle screw?
battousai
04-15-2012, 01:25 AM
i would only go with the tune, take it to a reputable shop in your area. and if it shakes the car at 1k, something is wrong.
aznbadboixx
04-15-2012, 01:53 AM
thanx for the help this is my first ls1 and its completely different from what I normally mess with. One more question will tuning be able to make it less loopy through some other means beside changing the idle?
BillyMitheRxguy
04-15-2012, 07:31 PM
which is the best cam?
BigBirdLS1
04-15-2012, 07:56 PM
If your car is rocking back and forth at a 1k idle I'd definitely get the tune looked at and check the motor mounts also.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
