Drivers seat lumbar moving passenger?????
When I mess around with the lumbar on my T/A it actually moves mine and the passenger seat... WHY???? Is it something factory or is it some kinda fluke I need to fix?
Thanks in advance!
Thanks in advance!
Moderator
Might be that there's a bit of crud in the air valving;
it all has one common pump and maybe when it runs
the pressure is bleeding into the passenger's side too?
The air pump and valving are all under the passenger's
seat, so if it's just noise that's normal. But they should
not be affecting each other pneumatically.
I set mine up and my cousin was in the pass seat.. moved his around and I didn't feel anything...
Ill see what happens here in a bit.
Still wonderin why... Jimmy... is it something easy to fix, or is that some oddball stuff?
