2001 z06 oil pressure issue
Old 04-15-2012, 02:42 AM
blackwidowSS's Avatar
Default 2001 z06 oil pressure issue
I noticed that the oil pressure gauge goes all the way up to 80..but on my dash display it says its 130psi..does anyone else have this problem? Or had anything similar happen to them??
Old 04-15-2012, 02:59 AM
LS1TA_956's Avatar
lol thats too much gl op might be a bad oil presure sensor its reading to high
Old 04-15-2012, 01:22 PM
Thanks..I'll check if it's a sensor
Old 04-15-2012, 01:29 PM
ZeeOSix's Avatar
Yep ... oil pressure sensor has failed. Very common issue talked about on the Corvette chat boards. You might want to go there and read the many DIY replacement threads for the oil pressure sensor.
Do a search for oil pressure sensor.
http://forums.corvetteforum.com/c5-tech-1/
Quick Reply: 2001 z06 oil pressure issue
