PCM Diagnostics & Tuning - Tuning Software Updates
ZL1Killa
04-15-2012, 04:53 AM
I'm not all about starting crap but I'm very curious what is going on with each company. Anyone have any insights or yearly reports? Are programmers hard to come by at HPTuners?
EFI Lives latest update was April 12th 2012 (NON-BETA) full public release
HPTuners latest update was June 26th 2008 (NON-BETA) full public release
I seem to see an increasing car tuning capability between the two that keeps getting bigger and bigger. Either there is going to be one hell of a release in the upcoming times or I guess it will just be adding cars I hope.
or am I missing something with the 2.23 beta release of hptuners? (I don't and haven't used the beta at all)
foff667
04-15-2012, 11:50 PM
Since 2.22 we've added so many new features and support its hard to imagine
E78 read support
E39 read support
E37 read/write support
NGC3 Dodge/Chrysler read support
We've also added support for a few new operating systems
L4
16253010 16259676 12225336 12206016 9382944
9364978 12223048 9365314 9364968 9356822
16254760 16254761 16267102 16254731 12578877
9387547 12218880 12205378 9353697 9383067
9356827 9373182 9365340 12580032 9387552
1220464 12201231 9373161 16259650 12206031
16250926 12578878 9393832 12217199 9365311
16254730 12206025 9392800 9357028 12201779
9352809 12218402
P11
12583785 12218881
P12
12597424 12607148 12610643
97 V6
16257531 16253031 16243827 16254062
16265838 16252926 16255243 16245670
16252952
P04
9374770 9352742 9389353 9352757
12218400 12223490 12578500 12223490
12201687 12618883 9376662 9389259
12573407 12584933 12226103 12221348
12218171 12203659 12211256 12201870
9389700 9389351 12223440 12211252
12596603 12211496 12218411 12211488
12223436 12618881 9384035 12205332
12201881 9389680 12213452 9352617
12618861 9367747 12218860 9377380
9378072 9357027 9381810 12211506
12205339 12207433 9384017 16266347
12583371 9378077 12218853 9366323
9352803 12221678 9383308 12223495
12223435 9363607 12223486 9369198
12223489 12618864 12216640 12203661
12201457 12214377 9352741 12580122
9357128 12594021 12221685 12580121
12201872 12201772 9389260 12585032
12201786
P05
12581052 12619744 12635879 12585294
12635874 12635875
97 LS1 V8
16259806
98 LS1 V8
9355168 9365940
P59
12578128
E37
12610011 12618032 12635865 12628829
12630187 12628960 12628961 12635399
12639473 12640965
E38
12635859 12636005 12635863 12639835
12628982 12639270 12630465 12649046
12647991 12653252
E40
12593827
E55
55573067 55573114 12623990 12595778
92179468 12621961
E67
12636036 12639469 12635904 19211212
12638778 12618044 12632176 12639299
12630458 12615634 12630360 12617747
12630465 12635457 12630367 12601719
12644041 12653238
E69
12629314 12634286
E77
12616452
T43
24253414 24254909 24252573 24249179
24257135 24261871 24236313
T42
24243902 24252617 24252956 24243356
24256876 24255281
A40
15878459 25982141 24256578 24256580
Ford
HABND HABS2 HACCE HACCD
HADCD HADCE HADCK HAEDG
HAEDD HAEDH HAAMC HAAMF
HAAMG HACCK HACH3 HAAS2
HAAS4 HAAP9 HACHD HACHF
FBMR1 HACE8 HACE3 HAAT0
HAAT2 FPBF2 FBBT0 FBCE0
HAFDF HAFDJ HAFFA TENF1
FPBX1 FBCE2 FEBF1 HAEE4
FOAR0 OKCM7 FPASB TADP6
FBRE7 FBLF2 FSAEA HACF0
HAEE3 FBMMB HAAO8 FOASB
FBHR2 TAZP2 HAAND HAFF9
HACD8 FNBD1 FMAG0 TDFG5
FBMMC
Vortec
16258745
Dodge
05030232AE 04896415AK 04896415AE 05030232AF
Added:
T43 Fast Learn vcm control
T43 Trans Cleaning vcm control
E38 Throttle Cleaned Reset vcm control
All ford operating systems receive
Max allow value for inferred map-“Calculated MAP Max” under engine-airflow-general-speed density
Max Load Seen By Engine-“Max Load”-under engine-airflow-general-speed density
Max allowed value of FP flow-“Fuel pump flow max” under fuel system-fuel pump
Fuel injector breakpoint multiplier for deltaP-“injector breakpoint mult vs pressure” under engine-fuel-injectors
I4 512k os 16250871 receives VATS Fuel Cut B switch
P12 pcm’s receive
To and from cobalt ss/sc unable to connect error fix
E77/E69 pcm's receive
Several overboost/underboost condition diagnositic test tables and constants
Map sensor tables
Wastegate & BOV tables
Fuel pressure tables
Injector tables
Fan tables
Spark tables
512kb & 1024kb LS1 platforms received
Options matrix
Platform type switch
Fan recirc switch
TPS High & Low fail constants
About a dozen new rolling idle tables and constants
IAT Scalar table
512kb LS1 pcm’s received
Cranking spark table
9375577 received TPS High & Low fail constants
os id 12212156 received
Upshift D2 2nd
Downshift D2 2nd
Upshift D2 3rd
Downshift D2 3rd
Following os id’s received Impact factor gain vs airflow, fuel on wall exp decay mult vs airflow, transient fuel min rpm, transient fuel max tps, min fuel milligrams & fuel from wall stabilization
12579405
12216125
Following os id’s received fan desired% v sect & dfco tps minimum
12579405
E38 & E67 pcm’s received
Roughly 50 new tables described here http://www.hptuners.com/forum/showthread.php?t=28498
The following E38 os id’s received 1-2.5 bar vcm enhancement:
12612381 12639270 12633056 12635863 12605732 12614676 12612281
12617631 12628990 12624402 12633016 12647991 12628988
E38 Starter check patch applied to:
12614676 12614088 12630501 12605732
12615493 12628983 12614682
E67 Starter check patch applied to:
12618164
E37 Starter check patch applied to:
12618032 12618044 12610011
E38 P2101 Throttle parameters added for
12617631
All E38 operating systems receive the following speed limiter constants
Speed Limiter 4WD Low
Speed Limiter Comms Fail
Speed Limiter Steering Fail
Speed Limiter Minimum
Speed Limiter ETC Fail
E67 OS id 19211212 received 1-2.5 bar vcm enhancement addition
E67 pcm's can now perform write calibration only without error
All E40 os’s receive cranking spark table
E40 os’s 12596734, 12604792 & 12596660 received
P2101 Throttle tolerance params
T43 TCM's received a major 150+ table update including TM & TCC lockup tables requested
GMPP E67 pcm support released
GMPP EROD pcm support released
2009+ Allison TCM support released
2010-12 Camaro V8 ECM/TCM support released
2009-12 Corvette ECM/TCM support released
2009-12 CTS V8 ECM/TCM support released
2009-10 Mustang V8 ECM support released
2009-10 Savana/Express V8 gas support released
2009 G8 V8 support released
2002-2011 Ford BA, BF & FG support released
2009-2012 Escalade ECM/TCM support released
2009-2012 Silverado/Sierra V8 ECM/TCM support released
2009-2012 Tahoe ECM/TCM Support released
2009-2012 Colorado/Canyon I4, I5 & V8 Support released
97-04 V6 pcm’s
Received several open loop and injector tables added to all 700+ operating systems
Ford credit licenses lowered to 2 credits for single vcm licenses
Ford Scanner rate updates for faster scanning
so we haven't been sitting on our hands over the last few years, we've just had to make alot of large code changes to both the editor and scanner that we've pretty much rebuilt each of scratch in preparation for dodge support. So yes it'll be a pretty big release once it goes public but its currently pretty stable as it sits.
ZL1Killa
04-16-2012, 02:50 AM
i had heard bits and pieces of things yall had been up to in the beta but did not realize that huge list you have there. I have never used the beta versions, I might have to try and test along with the others.
Jimmyz
04-16-2012, 01:51 PM
Does HP Tuners have 2012 C6 Corvette Z06 tuning, logging & editing capabilities today?
foff667
04-17-2012, 09:30 AM
Yessir
Higgs Boson
04-17-2012, 05:03 PM
HPTuners Beta is basically a "continually updated but not technically supported because it's technically a beta" current version. I update my HPT Beta software all the time, it seems like it gets something new once or twice a week, lol. And it pretty much never has bugs, maybe once in a while on a brand new OS the table will be labeled wrong or something.
The real actual new version of HPT must be a total game changer because it's been under development since the last carburator was installed at the factory....
MontecarloDrag
04-17-2012, 10:58 PM
So you are talking without knowing your facts??
ZL1Killa
04-18-2012, 11:40 AM
I essentially asked for facts in my statement, and he presented them.
Jimmyz
04-19-2012, 02:06 PM
Yessir
So when will I be able to connect the car with the my MPVI? I read the PCM but can't add the license to the device.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
