View Full Version : Cruise control issue not engaging
Wayfastwhiteyaz
04-15-2012, 04:23 PM
Last on my way home from work got up to 70mph on the freeway and went to engage the cruise control pushed the button In to set the speed and it wouldn't work is there an issue with a fuse being burn out or would it be a vaccum leak it's never done this before I use it all the time?
Wayfastwhiteyaz
04-15-2012, 07:23 PM
Wow 65 views and not one comment come guys I'm not the only one that's ever had this issue...wow maybe I should use the search button.
01BlueSS1995
04-15-2012, 07:30 PM
is the switch on the on position? :judge:
TransamGCS
04-15-2012, 07:41 PM
im interested in this my self as my cruise isnt working either. wayfast i believe if a fuse burns out the service vehicle soon light will come on. also what part of arizona do you live in
jsteele90
04-15-2012, 08:12 PM
there is a sensor underneath the brake pedal on my car which is a auto. it was not contacting the stop so i had to disconnect it and turn it a few turns till it was making contact and it fixed my cruise control gripe.
_JB_
04-16-2012, 07:24 AM
There is also a switch on the clutch pedal if the OP's car is a M6.
