Forced Induction - RUNNING boosted 4.8/5.3 guys
View Full Version : RUNNING boosted 4.8/5.3 guys
91sonomast
04-15-2012, 08:21 PM
There is all kinds of talk about the big boost 4.8 and 5.3 builds but I don't see very many people actually doing it or that are done including myself. I wanna see how many people have actually got their boosted 5.3 on the road and running.
What engine? What's done to it? What size turbo are you running? Meth? How much boost are you making? How much timing are you running? What kind of hp are you making or track times? Just trying to find some people that have it done and see some end results, this is a big idea since the Hot Rod issue but like I said, haven't seen many people actually doing it and finishing it.
1fast bird
04-15-2012, 08:33 PM
Do some searching. There are a bunch of guys running boosted 4.8/5.3's with crazy results.
Here.....
http://ls1tech.com/forums/forced-induction/1522770-my-79-fairmont.html
http://ls1tech.com/forums/forced-induction/1469908-year-ago-today-i-took-stock-shortblock-record.html
stangtrader
04-15-2012, 08:39 PM
Not 5.3 or 4.8 but I am running a stock lq4 in my camaro. I'm on 10lbs with the on3 Turbo on a rearmount setup. I'm tuning the car myself so no dyno numbers but guessing around 500rwhp from the car I ran last night. I'm running 17.5 degrees of timing according to my data logs with commanded 20°. No Meth on straight pump gas. I'm about to install my mbc up and start turning it up to around 18psi
a4ls2goat
04-15-2012, 08:58 PM
do some research man.
plenty of people out there making good power and running good track numbers on stock motors.
i just installed the meth on my 4.8 and will be getting tuned on the next couple of days on 16psi on a GT45.
denmah
04-15-2012, 09:38 PM
600rwhp is not hard to do through an auto ive done it many times.
gen3 or gen4 4.8 decent turbo 20lbs of boost on methanol 15-16deg of timing depending on cam and heads, gets the fastest mph, my friends 4700lb truck goes 126.50mph
denmah
04-15-2012, 09:54 PM
we drive our shit too
http://www.youtube.com/watch?v=_TWX8EZD2ek
denmah
http://www.youtube.com/watch?v=1PDWa3YdAEY
yenkm68
04-15-2012, 10:05 PM
5.3 ls7 cam,ls9 gaskets, arp rod and head bolts, and some good spring. on3 76mm turbo .81 ar, th400 , not big boost but 500rwhp and 690rwtq on 9.5 lbs on pump. they said i was good up 12 on pump. dont know the timing tho but could find out
denmah
04-15-2012, 10:27 PM
you can certainly make more power on pumpgas with methanol, unless you are out of injector.
denmah
04-15-2012, 10:30 PM
the fairmont is a 01. 4.8l it has a stock head, and a ported ls1 head (totally different heads but its what i had laying around, the one header bolt was so fucked up i drilled the head fucked up, got pissed off and just pulled the head and swapped it, used a USED 5.7 head gasket and ARP bolts, i run 12deg, 20lbs of boost, wawa92 pumpgas with 70% methanol water mix and she is retarded, i took it to the track and it went 11.30 @ 128.8mph on 14psi leaving like i was going to get groceries, didnt make boost till 100ft out, 2.0 60ft.
went 102 in the 8th mile lol
i could do at least 16deg on this motor on 20lbs since thats where our truck seems to mph the best...
that is the same setup, zr1 cam 08 4.8l, stock heads, 20lbs of boost(22 when the converer locks) methanol 70% 16deg of timing in it. 12.0 AFR average.
LS1NOVA
04-16-2012, 08:35 AM
2005 L33 5.3, 224/228 cam, Lunati duals, LS9 gaskets, ARP head studs, PT7675, 4" downpipe, 16psi, 17 degrees timing, E85, 11.5 AFR, 824 flywheel hp.
pwrtrip75
04-16-2012, 09:18 AM
Back in 2006 I built one for my Nova. Stock 5.3L MPGT45, 317 heads (mistake), 224/224 .580/.580 112 cam (spare laying around), TH350 TCI streetfighter. I ran 15psi + 50hp nitrous. 93 octane.
Home made intercooler. It blew through the converter about 1000rpms... but calculated out to 640whp. Ran for 3 years reliable, driven all over, and beat severly.
Finally spun a rod bearing.
westtexasbuff
04-16-2012, 10:01 AM
Buddy of mine slapped a 5.3 in his GT91 turbo'd C10. Stock bottom end, just regapped the rings, head/main studs, and ported 317s. Stock truck intake. He's running around 20lbs I think on e85. Spools well on the street. It was a built iron 370 before, something happened and it hurt the motor at the track, thus the reason for the 5.3.
http://www.youtube.com/watch?v=yjM3WCSHtuI
91sonomast
04-16-2012, 10:49 AM
I've done a decent bit of research and found some of these projects and results but was looking for more than a few cases. Glad to see these setup's are living up to the hype. westtexasbuff- I'm doing a build very similar to your friends, I'm regapping the rings, ARP rod bolts, ARP studs in the mains and heads, new bearings, 241 heads, and a 70-76mm turbo. Mileage on the motor currently unknown, little rust in one cylinder, going to hone it and hope for the best lol. What do you base your ring gap specs. off of? My main hold up is the victim of the setup needs work.
Keep posting if you have experience with it.
trav-tech
04-16-2012, 05:32 PM
04' 5.3L 76mm turbo @ 16psi 690whp vp110 fuel 60lbs injectors 95% duty cycle (maxed out) 232 dur .560" lift 114lsa cam. heads and gaskets, bolts untouched. arp rod bolts clevite rod bearings, mellings hv oil pump. its a drag car only but have about 60-70 passes on it. soon it will be getting 80lbs injectors and going to open gap on top ring and do arp head bolts and a set of 243's and bump to around 20-21psi boost. going to shoot of 800+whp or bust.
chevellepowered
04-16-2012, 09:39 PM
travtech what turbo u using..brand i have simlair setup..
trav-tech
04-16-2012, 10:54 PM
Unfortunately I really dont know much about the turbo. I got it second hand (was on a 2.1L four cyclinder that rand mid to high 7's 1/4mile) it is stamped "TEC" on the comp housing. 76mm wheel cold and p trim hot with a 1.15ar t4 divided tang housing.
91sonomast
04-16-2012, 11:14 PM
I think TEC is Turbo Engineering Corporation.
trav-tech
04-16-2012, 11:39 PM
Yeah I went to their site and could not find much info. I should call them and see what They can tell me about it. It's like 12 years old though. The best part is that I got it for $250 and it had a brand new cartridge in it. It had a 1.52ar housing on it when i got it i put the 1.15 on that I had laying around. I think i'm going to try it with the larger housing when change the heads.
skinnies
04-17-2012, 12:53 AM
See my sig, both cars are on e85
