do LQ9 rod bolts need to be upgraded?
Old 04-15-2012, 09:14 PM
ANTICOP RAM AIR's Avatar
Default do LQ9 rod bolts need to be upgraded?
Im about to do the swap in my 99 TA.. Trying to think of all the crap I should do when the motor is on the stand... suggestions?
So far, Ive got:
New front/rear cover seals
Oil pan gasket
Timing chain
What else can I do? I want to do the rod bolts with ARPs. I can just pull one bolt and replace it with the ARP? Then torque to spec, right? Seems like Im missing something...
Old 04-16-2012, 10:55 PM
3rdCoastPowerSports's Avatar
ARP requires resizing the rods. I believe Kartech bolts are a direct replacement and don't require resizing. Are you planning on pulling the heads off?
Old 04-17-2012, 05:11 AM
mark21742's Avatar
On my first ls1 I used the Katech bolts, just like you said, take them out and replace them one at a time and never had a problem....the Katech bolts even held strong when I sucked a bunch of water in and blew number 7 rod out the side of the block lol.
I'm running ARP bolts in my engine now (had them resized) and working great.
So either way will work
Old 04-17-2012, 07:09 AM
I wasnt planning on pulling the heads... is there a reason I should?.. this motor is clean clean clean inside and has about 53k miles.
Old 04-17-2012, 09:11 AM
trans_am7935's Avatar
it is always a good idea, cause all people lie, especially to sell something they don't want. so if you have another 1-200 bucks laying around, pulling the heads is a good idea
Quick Reply: do LQ9 rod bolts need to be upgraded?
