Forced Induction - Boosted Ls3 intake ?
View Full Version : Boosted Ls3 intake ?
CyaPussy
04-16-2012, 08:19 AM
What are you guys putting in the hole where the map sensor goes on the front of the intake so that it does not blow out under boost?
LS1NOVA
04-16-2012, 08:32 PM
Ive used an 1/8 npt plug threaded into it on an LS1, Im assuming that would work.
1Legged60ftHnter
04-16-2012, 08:38 PM
My question to you is: Where are you putting your map sensor? I was just planning to extend the harness and run the map sensor in the front of the intake where there is a provision for it rather than plug the hole.
So.jerZ-28
04-16-2012, 11:01 PM
Same thought I had... hope your not drilling a hole in rear of intake to install map in stock ls1 location... that would be just assinine.:corn:
Oh4GTO
04-17-2012, 12:32 AM
I put the MAP sensor there. Perfect fit actually.
CyaPussy
04-17-2012, 08:34 AM
My map sensor is connect with a peice of tubbing below the hole. Im scared to thread anything into I dont want it to blow through the hood of my car any other ideas?
thirdgen60
04-17-2012, 07:37 PM
blow through the hood??? pretty sure that wouldnt happen even if it came out. If you arent using it and dont want to thread something in it, just machine a flanged plug with an oring groove and clamp in the hole
