Gears & Axles - How much can my 10-bolt take?
View Full Version : How much can my 10-bolt take?
98BlackTransAm
04-16-2012, 11:20 AM
I have 4.10's in the stock rear-end and I'm making ~380rwhp. I know it's not that much power, but I've heard how notorious the rear-ends are for breaking. I rarely ever launch it hard from a dig and I haven't run it at the track yet, but do you think it would be safe to do some burnouts and launch on DR's at the strip as long as i don't dump the clutch too hard?
I used to have a stalled auto that I beat the hell out of and ran at the strip several times and never had any problems. I know the autos are more durable though. What are your guys thoughts?
JUSTINSWS6
04-16-2012, 11:23 AM
ya i think you will be fine. i really never see them break unless you hook. If you dont hook it normally doesnt break. Burnouts dumps at 4000 rpm should be fine. not saying it wont break there is always a possibility.....
allout06
04-16-2012, 12:12 PM
i just busted my rear about 2 weeks ago. had 383rwhp goin to.it for about 6 months and 571rwhp for about 4 months... 0 track time and no hard launches on it. its a matter ot when its going to break not if its going to break lol.
heymoej
04-16-2012, 12:37 PM
in my 2000 SS M6 my stock clutch & rear end starting to be not very happy with me @ about 380rwhp......and that was with about 9500 miles on the car.
if you dont have the money to fix it,dont put sticky tires on it at the track....sticky tire alert!
good luck!
Rob94hawk
04-16-2012, 01:02 PM
I wont even put drag radials on my stock rear that's how much I trust it.
VincesSS
04-17-2012, 02:18 PM
Mine has taken quite a bit of abuse at my power level.. 3 years worth, probably 25 passes~ and a handfull of nitrous passes (1.6/1.7 60's 500whp). I make sure to have very slight engagement of the clutch before letting it go. Completely stock rear with 3.73s, no girdle or anything. It does whine a lot now though.
predatorz28
04-17-2012, 02:26 PM
i just busted my rear about 2 weeks ago. had 383rwhp goin to.it for about 6 months and 571rwhp for about 4 months... 0 track time and no hard launches on it. its a matter of when its going to break not if its going to break lol.
This lol
fccs
04-17-2012, 02:47 PM
I just broke mine yesterday lol
66vert
04-17-2012, 02:51 PM
i just sold my 8.5 10-bolt. 31 spline rear axles. Eaton posi 3.73's built by pro-gear in san diego with a T/A cover. They said 550HP max in that configuration. It was a great rearend for average street car running 400HP.
chasgiv3
04-17-2012, 03:15 PM
The 10 bolt is made of glass. I wouldn't let someone play loud music near it!
Platinum WS6
04-21-2012, 06:52 AM
In stock form mine broke twice, the first time with the factory tires on low pressure. Now with the setup I have I am just praying it will handle the stock tires and NO launches lol! I do believe you can get a few good passes on them but it is only a matter of time before those little 7.5 " gears say "IM OUT"...........thanks GM
BOBS99SS
04-21-2012, 07:11 AM
start saving for a new rear now, so when it goes ya can afford to put something good in it,once you get a solid rear in there it makes the car so much better,
allout06
04-21-2012, 07:35 AM
^this
that's y i ordered my MWC 9" and full suspension a month and a half ago....i knew it was gonna break soon cuz it was getting noisy. sure enough, it broke about 2 weeks ago and my new rear will be here next week :). start saving, cuz its expensive....... :(
JUSTINSWS6
04-21-2012, 09:04 AM
^cost me from mwc 3400 ish with rear and 3.5 drive shaft
allout06
04-21-2012, 09:46 AM
i got the 9", strange lite weight spool, 35 spline strange axles, Daytona pinion support, nodular center, back brace, and transverse shock mounts, drive shaft, LCA, PHB, TQ arm, driveshaft safety loop w/crossmember and TQ arm relocation bracket, anti-roll bar, DA strange front coil overs, SA rear coil overs, SFC's.
housing is powder coated black the suspension pieces are red.
i think my total was $5600
