Road Racing - Cheap Camera/Mount Example Vid
View Full Version : Cheap Camera/Mount Example Vid
ZexGX
04-16-2012, 11:48 AM
Hey guys, just wanted to share something I came up with a while ago but wanted to do a real course test first before sharing in this subforum. It's a cheap camera mount and cheap HD camera solution (if a GoPro is "too expensive" or "overkill" for what you would use it for).
http://img37.imageshack.us/img37/1096/p1100572v.jpg
The only real con is that you need to rotate the video 180* using a computer (if you use the exact mounting method I used), but Youtube or a computer with Windows Movie Maker or another basic movie editing program can rotate the video. I saw somebody with a C4 Vette at the same event that had a similar Flip camera mounted to a suction cup mount on the exterior of the car.
Details of the mount are here: http://ls1tech.com/forums/stereo-electronics/1448544-cheap-camera-mount.html
Example video (check out those slaloms.....). I separated the mirror from the arm, so it was just the arm & camera mounted to the windshield mirror mount.
http://www.youtube.com/watch?v=3RfBMGy2YOw
The camera used for this was a first generation Flip Mino HD, which can be found for around $50 on Craigslist. The newer Flip Ultra HD shoots in 60FPS which means it produces a much clearer video than the version I used. Wide angle lens conversions can also be done if necessary:
http://www.youtube.com/watch?v=-nQUog2TpY4
One day I'll see about doing a side-by-side test with a GoPro to compare.
95ONE
04-28-2012, 12:54 PM
Great idea and examples. Thank you for that.
Transamtx
05-23-2012, 03:21 PM
That is very innovative...great job
