Fast 95 Z28
04-16-2012, 01:03 PM
Hi, just wrapping up my 408 build just want some ideas what it will dyno around, just want a ballpark guess. I care more about running high 10's/ low 11's :burn:
Motor specs follow:
2003 LQ4 408 Stroker
Wiseco -8cc dish pistons
Forged eagle 6.125" rods with ARP 2000 Rod bolts
Callies Compstar 4" Stroke crankshaft.
.045" gaskets for .037" quench
Custom Pat G cam (23x/24x) .617/.615" 110LSA+4 advance
LS7 Lifters
Comp Cam 7.400 chromoly pushrods
Lunati Dual Gold Springs .660" lift
Melling Stock Replacement Oil Pump
Stock LS3 heads (821 castings with LS3 hollow intake valves)
Victor jr intake (might port match it to heads)
Holley 750 double pumper
Static compression ratio: 10.72:1
Dynamic compression ratio: 8.49:1
Running 91 octane at sea level.
Th400 with 3500 stall, 12 bolt 3.73 rear gear, 28" rear tire.
Hooker Long Tubes 1 3/4" Primary 3" collectors
Revving the motor to 6800-6900, Redline 7000rpm
The motor is going in a 1970 Trans AM weighing about 3400-3500 RACE WEIGHT
Hoping for 480-500rwhp and high 10s!
Motor specs follow:
LS7 Lifters
