what else do i need victor jr efi
Do you have the intake gaskets and the gasket for between the intake and elbow? the fuel lines to the fuel rails, and the fuel line to connect both fuel rails with all the fittings? I believe Nasty Performance sells the complete fuel lines and fittings needed. I also done a ton of research looking for ARP 12 point hex head bolts to use rather than the ugly looking bolts supplied by Edelbrock that connect the intake to the heads. If you're interested in them, they are special order and the part number is 770-1010. You will need to buy 2 sets, 5 come in a set.
I am going with the Super Victor Jr. intake with the 6061 elbow on my 408.
http://www.nastyperformance.com/shop...l-install-kit/
Will connect you rails to the factory feed line.
fittings and lines i can get from hp sales or murrays that are right around my house. thanks for that info. the intake supposedly come with the gaskets not tb or elbow, but the tb should be like my stock one correct im going to be using my stock ported tb for now. im on a budget. will i need to run a fuel pressure regulator ? or and i leave mine stock for now? im looking to drop in the intake and then ill go getting the rest of the stuff to finished the build.
i wanted to go super vic, but i was going to have bigger problems with clearance. so i went jr the super vic is like 1.14 taller than the jr, so i didn't want to go that route for that reason. i still have stock hood.
The elbow to intake gasket is just a regular 4150 square bore that you can get at any auto parts store.. Depending on what elbow you have, it may or may not be o-ringed for the factory syle tb o-ring.. You may have to use a flat paper style.. Intake should come with the two fittings for the map & brake booster hose.. I had to extend my map pigtail about an inch or so to reach the new location on the vic jr. I would highly suggest getting a set of hardened intake bolt or arps.. The ones Edelbrock supply are junk.. I had the rear pass side bolt snap off while torquing it. You also might want to get a vacum tee for your hvac system & your factory fuel reg will be fine for your set-up.
got everything in last night but was to late to go out and install will start today love the look of the mani i know the elbow is backwards just put it on for picks lol
Ok just finished the swap turned on the car idled like **** and it pooring gass out the exhaust what can be wrong double checked everything and can't seem to find what's wrong
