installing an electric fuel pressure gauge
I recently bought some cyberdyne gauges (trans temp, fuel pressure, oil temp, oil pressure) and the oil pressure and fuel pressure sending units look identical.
http://www.summitracing.com/parts/CYB-SENSS2E/?rtype=10
http://www.summitracing.com/parts/CYB-SENSS4E/
I already removed the internals of the schraeder valve and now I'm stuck with what to do.
I called summit and they said "according to autometer, I have to buy an adapter with a hard line" and that costs over $40 that seems a little crazy to me, but idk
So if anyone has an electric fuel pressure gauge installed with the sending unit, please help me out!!
I just bought these to work with my Glow Shift electric fuel pressure gauge. These parts will allow you to hook up the electric sending unit to the schraeder valve. If your sending unit is the same as glow shifts it will work. Hope this helps.
Summit:
EAR-968604ERL
SUM-220441N
Summit:
EAR-968604ERL
SUM-220441N
If its electrical there is no line that runs to the gauge that carries the any fluid or air (depending on what the gauge is for).
It uses the sending unit that sends a voltage to the gauge and the gauges uses the voltage to determine the psi.
I hope you didn't buy the second one as its only for 0 - 16psi.
If you have an aftermarket FPR, most have a plugged port that you can use for a fuel pressure sending unit. If not, then the parts posted to link to the fuel rail valve will work.
Summit:
EAR-968604ERL
SUM-220441N
Summit:
EAR-968604ERL
SUM-220441N
