Manual Transmission - Machine down regular LS1 input shaft and use the larger pilot bearing
Hans Grüber
04-17-2012, 04:01 PM
I have an LS1 input shaft that has the end galled due to a bad pilot bearing.
Can I simply re-use this input shaft if I machine it shorter to use larger Corvette
pilot bearing as shown here:
http://ls1tech.com/forums/13649428-post10.html
Would I have any foreseeable issues with the clutch if I do this?
Do the TR-6060 transmissions in the 2010+ Camaro use this style pilot bearing with a shorter input shaft?
thesource
04-17-2012, 04:37 PM
We just cut the tip down and press a case hardened bushing on the end of it. This is actually better than stock because the thickness of hardened material is thicker than what comes from Tremec.
Hans Grüber
04-17-2012, 05:28 PM
Do you know what the nominal tip diameter is?
Also how much does your repair cost?
