Turbo Guys let's talk motor mounts!!!!
Old 04-17-2012, 08:53 PM
RacerXLs1's Avatar
Cool Turbo Guys let's talk motor mounts!!!!
Ok guys have a quick question, what mounts do you have on your car and tell me why.. I have a stock k member, and I was looking at the umi soild motor mounts.. A little about my car
LS2
Th400
Kytp hot side pt76
I want to run my down pipe thought the bumper or pass fender.. So let me no what's the best choice. I tryed searching but came up with nothing.. Thanks Andrew
Old 04-17-2012, 09:16 PM
BottleFedZ346's Avatar
If your downpipe is going thru the bumper then there's really no need for new mounts.....
Im running the Spohn solids (stock k-member) only because it gives me a little more room if i ever did decide to put a full exhaust on the car.....
Old 04-17-2012, 09:26 PM
RacerXLs1's Avatar
Ok so should I keep my stock mounts or go after market, the only reason I'm asking is cuz I'm putting the motor in this week and don't want to do it again. Andrew
P.s sorry for the messy post
Old 04-17-2012, 09:56 PM
Up to you really, if you dont need them then i see no need to spend the extra cash, put it towards something else you need....
Old 04-17-2012, 10:23 PM
Adam86's Avatar
I have poly mounts on my car with a stock k-member. Only running a 3" downpipe and had to notch the k-member. Not much room down there with stock gear!
Old 04-17-2012, 10:31 PM
salemetro's Avatar
BMR Turbo k-member here with poly mounts. Nice thing about the poly mounts is that they never deteriorate....as long as you don't cook them from being too close to the turbo downpipe. Usually not an issue.
Old 04-18-2012, 05:06 AM
RacerXLs1's Avatar
Bump keep them coming
Old 04-18-2012, 06:48 AM
dschmittie1's Avatar
BMR turbo K member and poly mounts here.
I would at least do Poly mounts that will help with reduce the amount the motor twists. No need to run solid mounts
Old 04-18-2012, 07:01 AM
turbocamaro125's Avatar
I am building a buddies camaro now with stock k member and 4 inch dp thru the k member has spohn solid mounts
Old 04-18-2012, 07:13 AM
RedRocketZ28's Avatar
I am running Spohn solids. However, I am using the stock K-member and running the down pipe through there. If you are going out the fender, and your current mounts are good, spend that money elsewhere like mentioned above.
Old 04-18-2012, 08:01 AM
Toxic-Evo's Avatar
DKTBMR mounts with poly, with BMR kmember,
why.... needed to clear the S cover on my 6766.
also GODS of room now.
Old 04-18-2012, 08:33 AM
Restricted User
98Z28CobraKiller's Avatar
I am using stock manifolds and my downpipe is not all that close to anything under there and my poly motor mounts melted like they were made of wax on both sides. I bought these from UMI and no problem since. No noticeable change in ride quality or vibration.
I still have the poly cross member mount.
Quick Reply: Turbo Guys let's talk motor mounts!!!!
