No Spark..... No RPM.....
Old 04-17-2012, 09:11 PM
2 Stroke Racer's Avatar
Default No Spark..... No RPM.....
Problem I believe was caused by low voltage issues. Replaced battery and car just turned over fast without spark. Ran fine before weak battery issue, Also not showing RPM on hp tuners while cranking over. I am guessing maybe crank sensor?? I have one ordered and will try that first. Car is a 98 SS full bolt on cam-only with spray. Tested timing tuner and it's fine. Any suggestions would be appreciated. Thanks.
Old 04-17-2012, 10:49 PM
stangtrader's Avatar
Were you tuning the car on a weak battery?any codes stored?also have you tried a vats relearn just in case?
Old 04-17-2012, 11:09 PM
Nope, wasn't tuning. Car was running fine. Battery went dead from not being driven/started often. Charged battery, car barely started but rpm were up and down, so I installed a new battery and car just turned over fast with no spark.........
Old 04-18-2012, 05:35 PM
Any Ideas?? Anyone?
Old 04-18-2012, 07:29 PM
studderin's Avatar
Your car slow junk, sell it for a nice mustang
get the new cam sencor in?
Old 04-18-2012, 08:14 PM
Lol.... Not yet. Its ordered...
Old 04-20-2012, 04:20 PM
Over 150 views and noboby has any suggestions???
Old 04-21-2012, 05:50 PM
mantycarguy's Avatar
Check all of your grounds. This may cause both your charging/low battery voltage issues as well as a no spark/rpm problems.
Old 04-22-2012, 09:39 AM
All grounds seem to be ok. Thanks for the reply.
Old 04-22-2012, 12:38 PM
Moter's Avatar
Have you tested for spark? Do you know if you have injector pulse? Have you checked all fuses and fuse links? Do you get any codes?
Old 04-22-2012, 02:49 PM
Getting no spark. All fuses, relays, etc seem good. No codes.
Old 04-22-2012, 03:02 PM
Moter's Avatar
Do you have injector pulse?
Old 04-22-2012, 04:04 PM
I'll check.
Old 12-30-2014, 02:48 PM
strracer09's Avatar
Did you ever find out what it was? having this same problem?
Old 12-30-2014, 03:08 PM
thunderstruck507's Avatar
This has been a crank sensor or crank sensor wiring problem every time I've encountered it.
Quick Reply: No Spark..... No RPM.....
