Tloddy
04-17-2012, 11:10 PM
2001 Camaro SS 144K miles, 6 spd, t-tops. Spun a rod bearing and fixed the car with the intentions of keeping it. It had a lot of issues and was tired of fixing something once a month so I rebuilt everything except the transmission. Sold the old engine and started from scratch. Going to start a 100 mile a day commute and don't want to kill my wallet. Here's a list of the good and the bad.
About 200 miles on evrything below
Bought a used shortblock and replaced the cam, rod, and crank bearings and rings
ARP rod bolts
Custom cam 232/236 .601/.601 112 LSA
Lunati Lifters
TSP 7.4 pushrods
Cloyes billett timing chain
Ported LS6 oil pump
MLS head gaskets
ARP head bolts
241 heads milled .010, bowl and throat blend, valve job, PRC dual springs rated to .675
Factory LS6 intake
Fast 42lb injectors
SPEC stage 2 clutch
Motive 4.10 Gears
Rear end rebuilt with ratech bearing
All new gaskets
Brand new oil pan
KYB rear shocks
All new sensors
Mail order tune Tunedbyfrost
New rack and pinion
The things below have about 5000 miles on them
Walbro 255 lph fuel pump
Pacesetter 1 3/4" headers
Offroad Ypipe
Dynomax muffler
Sumitomo HTR Z II tires
Front and rear brakes
Kenwood CD Player
Kenwood 6 1/2 door speakers
Boston Accoustic 6 1/2 rear speakers
Rockford Fosgate Punch amp
Rockford Fosgate Punch 10" sub in custom enclosure
The Bad
The front of the hood is chipping
There is a little spot on the hood and a couple of spots on the spoiler where the clearcoat is coming off
Had a dent popped out right behind the drivers door. You can still see it but you have to look for it
It could use the tint is pealing and needs attention
ARP rod bolts
Lunati Lifters
TSP 7.4 pushrods
Ported LS6 oil pump
MLS head gaskets
ARP head bolts
Factory LS6 intake
Fast 42lb injectors
SPEC stage 2 clutch
Motive 4.10 Gears
All new gaskets
Brand new oil pan
KYB rear shocks
All new sensors
New rack and pinion
Offroad Ypipe
Dynomax muffler
Kenwood CD Player
The Bad
