Forced Induction - T/A 5.3 GT45 Turbo e85 (UPDATE Start Up Vid)
831jd
04-18-2012, 12:47 AM
Doing a swap on my 1996 trans am
specs:
stock bottom 2002 lm7
custom cam
Victor. Jr
truck manifold turbo kit
e85
4l80e
8.8 rearend
looking for some solid 10 sec passes, then turn up the boost and see what she does
sorry about my cheap phone pics will get better ones asap... thanks, any advise WOULD BE GREAT!!!!!
831jd
04-18-2012, 01:11 AM
A Poor mans BMR k member lol doing a quick red spray paint on it. Installing a ls1 k member with solid Motor mounts
831jd
04-18-2012, 01:16 AM
painting the engine bay flat black....:chug:
831jd
04-18-2012, 01:18 AM
needs a few more coats, way cleaner then how it was.
831jd
04-18-2012, 01:30 AM
mocking up engine and cleaning up.
831jd
04-18-2012, 09:19 AM
Any one know what gears would be best I was thinking some 3.27, 3.08? Will. Be running a 295 55 15 m/t
831jd
04-18-2012, 01:21 PM
Does Anyone know if a s475 83mm t6. 1.10 a.r be enough Turbo to push my set up passed 600rwhp or is the 74mm comp to small or should I just save up for a s476...
360demonRT
04-18-2012, 06:14 PM
from everything i've read on here, that turbo should be plenty for 600rwhp. i am working on a similar setup (5.3, vicjr, 4150 tb, s475 but with 1.32 and e85). be interested to see your reults. good luck!
831jd
04-18-2012, 08:32 PM
THANKS, why did you go with the 1.32?
831jd
04-19-2012, 04:48 PM
Got some more parts today ! Meth kit, ls6 cam, pushrods, springs, and picked the 4l80e with stock stall for 400.00
831jd
04-23-2012, 11:28 AM
While I sold my ls6 cam and springs. Got a deal on a custom cam and buying some 660 lift springs
Transam Rocket
04-23-2012, 11:16 PM
Really cool build should be fun car to drive
ep142
05-07-2012, 07:40 PM
going with the on3 76 turbo after all
what a/r did you go with
831jd
05-26-2012, 10:45 PM
Got the cam in today and valve springs bolted everything up engine and 4l80e going in the car monday.
a-low
05-27-2012, 07:54 AM
Where did you score the 4l80e from? Ive searched a few areas here in so cal and havent came across one yet.
831jd
05-27-2012, 11:49 AM
Got it off a friend in town. He took it out of a wreck van
831jd
06-06-2012, 01:00 AM
Got the engine and trany in!
831jd
06-06-2012, 01:07 AM
Test fitting the inercooler
831jd
06-07-2012, 12:44 AM
:eek2: Gt45 Turbo came in today and mounted the meth tank.
831jd
07-30-2012, 06:07 PM
I really want to ditch the pump gas and meth kit for some e85 will 60lb injectors max out before 600rwhp on e85? If so will I need a fuel pressure regulator for 80lb injectors... Im running a vette fuel regulator right now.
a4ls2goat
07-30-2012, 07:04 PM
just go with the 80lb injectors
831jd
10-26-2012, 01:25 AM
few pics... getting closer
denmah
10-26-2012, 06:53 AM
gt45 is a beast!
WheelsUp84z
10-26-2012, 07:03 AM
setup looks good, glad to see your swap crossemember fit much better than mine did with solid motor mounts!
831jd
10-26-2012, 10:01 AM
gt45 is a beast!
Sure is!! Just hope my junk runs aleast half as good as yours did. Im really thinking about pushing it to 18-20 psi for high boost
831jd
10-26-2012, 10:11 AM
It fits good way more space. Just had to notch the 4l80e crossember a bit.
pwrtrip75
10-26-2012, 12:41 PM
I dont think you need meth. My first turbo setup I built was a GT45 5.3L
29.5 tires, 3.50 gears, TH350, shitty TCI streetfighter converter went 10.30's @131 in a 3660lbs car. 15psi boost on 93 octane. Wish I would have played with E85 back then... would have been in the 9's easy.
I dont think you'll have issues meeting your goal....and then some.
831jd
10-26-2012, 01:09 PM
Wow nice. Yea ill be just running a fmic with e85 no meth. Ill be running the new 275 60 15 et m/t pros and a 3400 stall and transbrake. You think maybe I can sneek a 9 sec pass then on 18-20 psi lol should weigh around 3200-3400
pwrtrip75
10-26-2012, 01:23 PM
I was blowing through my converter quite a bit. It was my first setup and a whole new learning experience. The power you will make will get you well into the 9's... Your converter, trans, and rest of the car setup right... no prob.
WheelsUp84z
10-26-2012, 01:40 PM
well this is what I had to work with, when I used the "swap" crossmember and solid motor mounts.. Needless to say I had to make my own HAHA
http://i1160.photobucket.com/albums/q487/Juiced95Z/43EE1D04-EDA4-409C-B6A6-2C493C9D91E8-15294-00000CA0958D4DE3_zps02dca5ca.jpg
831jd
10-26-2012, 02:03 PM
[QUOTE=WheelsUp84z;16844851]well this is what I had to work with, when I used the "swap" crossmember and solid motor mounts.. Needless to say I had to make my own HAHA
http://i1160.photobucket.com/albums/q487/Juiced95Z/43EE1D04-EDA4-409C-B6A6-2C493C9D91E8-15294-00000CA0958D4DE3_zps02dca5ca.jpg[/QUOTE
Dam and I thought mine was bad lol what happen there? I had to use a stock lt1 trany mount and pull the trans a lil down to line up.
Strokinit383
10-26-2012, 02:04 PM
Nice build.
831jd
10-27-2012, 04:33 AM
Does the BOV placement look ok?
831jd
10-27-2012, 04:37 AM
Mounted the catch can, ran a line from both valve covers.
831jd
10-30-2012, 01:54 AM
Picked up a tunnel mounted adj. torque arm.. im going to reinforce the tubes on the torque arm also.
a4ls2goat
10-30-2012, 02:24 AM
The best place for the bov is right before the throttle body.
831jd
10-31-2012, 01:30 AM
Relocated the battery to the rear and the coolant over flow tank.. can keep it hidden also.. AND YES, i will be using another battery lol..
831jd
12-11-2012, 01:25 AM
finally started making the hot parts and finished the cold side.:guns:
831jd
12-18-2012, 04:28 PM
First start up! http://m.youtube.com/watch?v=R7VBQiyROP8#
831jd
01-25-2013, 01:31 PM
http://m.youtube.com/watch?v=nGXXS2espVU another idle vid
HRHohio
01-25-2013, 03:56 PM
Nice! That cam sounds BEEFY! What specs, if you don't mind.
a4ls2goat
01-25-2013, 03:58 PM
sounds good
831jd
01-25-2013, 06:01 PM
.583/.581 228/228 113 lsa I think ill check the card when I get home
831jd
01-25-2013, 08:48 PM
morepics:nod:
831jd
01-25-2013, 08:56 PM
and more pics :D
a4ls2goat
01-25-2013, 09:18 PM
How much power are you looking to make?
831jd
01-25-2013, 11:15 PM
At least a lil over 600rwhp on 18psi
831jd
02-13-2013, 11:46 PM
Will a fuel pressure regulater from 30-65psi would I be ok with the most pressure I can do is 65psi or do I need a 70-75psi one? I have 80lb injectors and twin in tank pumps
831jd
03-19-2013, 12:18 PM
So I'm about almost done with the build. The car should be getting tuned next week. I have a quick question. I'm running a MBC and a tail 38mm wastegat do I connect the side port of the wastegaste to the manual boost controller and leave the top port open?
chiaj144
03-19-2013, 05:57 PM
Yes. My 5.3 made 587rwhp at 12.8lbs with a little mpt70 so you will make your 600 no problem.
831jd
03-19-2013, 06:07 PM
Thanks! Can't wait to see what it makes at 18psi
ls6-240sx
03-19-2013, 10:27 PM
Cant wait to see what it makes. We have pretty similar builds except i have a 76mm .96ar
Mines on E85 as well right now its tuned at 15psi and 16 deg. never been on a dyno or track yet. I am hoping for the same results as you.
What heads are you running?
831jd
03-19-2013, 11:00 PM
706 heads
offaxis
04-06-2013, 08:20 AM
Any updates ?
831jd
04-06-2013, 12:35 PM
Not much I will be tuning it next week and will be taking it to the track April 20th ill post the dyno #s as soon as its done
831jd
05-03-2013, 08:51 AM
Turbo ls1 - YouTube
while i took the car to get tune a few days ago but didnt get finished on the first pull on boost it blew a heater hose and the charge pipe. it was getting way to hot also. Ran out of time since we tuned other cars and had to leave. Posted up a vid this is with no timing and super rich. Will be going back in a week
SSZ
05-03-2013, 10:57 AM
God you must be just itching to get it tuned and driving. Hope she pulls good numbers for you.
831jd
05-03-2013, 02:37 PM
God im dieing i want to push the crap out of her lol the turbo sounds so sick lol
