sheaadams86
04-18-2012, 05:36 AM
I'm trying to figure out which bearing is bad and if its worth changing out without changing for a new clutch flywheel...
Fire motor up, clutch chatters, if I push the clutch down and let go, it either gets alittle quieter or goes away, then if I push it down again, once again randomly stays quiet or starts chattering noise again, and repeat with same outcome back and forth, which is bad? Is it worth pulling trans to replace?
*note,- bought from friend couple months ago, he bought from someone year before that who said they put stage 2 clutch, not sure what brand tho....
Clutch still grabs hard, what should I do, really don't have a lot of money for the best flywheel/clutch combo right now?
