Generation IV Internal Engine - Eagle crank recall?????
View Full Version : Eagle crank recall?????
Jrp1978
04-18-2012, 06:27 AM
Eagle Forged 4340 Crank Chevy GM LS1 LS2 LS6 4.125" 58T
MY QUESTION IS !!!! EVERYONE IS BACK ORDERED ON THIS CRANKS BIG NAMED SPONSORS BU THIS GUY HAS 10 EAGLE CRANKS INSTOCK ! WAS THERE A RECALL OR SOMETHING HERE ?
87silverbullet
04-18-2012, 08:15 AM
I wouldn't buy from that site if my life depended on it. Look at the title then look at the description.
In the title you can clearly decipher 4.125 58 tooth then you look at the description and you see 3.622 24 tooth. So which one is it?
The part number ran thru eagle's site shows its a 4.125 crank and 58 tooth.
http://www.eaglerod.com/index.php?option=com_content&task=view&id=21&Itemid=32
What crank are you looking for? Plus how fast do you need it? Summit can get either crank shipped out by the 4/30. Jegs can get the 3.622 shipped out on 4/26
Jrp1978
04-18-2012, 08:23 AM
OK I will go with 4.100 for texas speed ! What is part # for cosmetic .040 heads gaskets for a 4.030 piston so i guess a 4.060 .040
Jrp1978
04-18-2012, 08:31 AM
I was looking for a 4.125 with a 58 its for a 420 ls2 going into a g8 ! I need it asap !
87silverbullet
04-18-2012, 12:14 PM
Here you go, take your pick on the head gaskets.
http://sdparts.com/category/cometic-mls-head-gaskets
As far as your crank, I personally wouldn't use an Eagle crank. Its just from personal opinion and experience. I use Callies exclusively.
http://sdparts.com/category/crankshafts
