Z28-4Ever
04-18-2012, 01:21 PM
when i use my key to lock the car, every few seconds my alarm will beep then stop, then start beeping again, but when i manually lock the car it doesn't do it. can someone help me out with what the problem is?
bad_408_vert
04-18-2012, 01:30 PM
Remove the shock sensor in the hatch, by the spare tire.
Removing it doesn't disable your alarm / keyless features.
Its going crazy because of moisture build up.
You can leave it open and set it to dry but it might just have moisture build inside it again.
Z28-4Ever
06-07-2012, 02:24 PM
well i took it out of the back to see if there was any moisture in it and it looked fine, so i hooked it back up and locked it with the remote and it beeped once and hasn't gone off since but it still beeped.
