LT1 to 5.3 turbo swap
Old 04-18-2012, 04:55 PM
slomarao's Avatar
Default LT1 to 5.3 turbo swap
looking for guys doing this currently.... i may be doing it over the winter so i want to check out threads, get ideas, etc etc
Old 04-19-2012, 03:05 PM
slomarao's Avatar
any 1 ??
Old 04-20-2012, 12:23 AM
the_merv's Avatar
Look into the stickys up top.. There is a LTx to LSx thread.
Old 04-20-2012, 04:21 PM
slomarao's Avatar
i want to keep AC when i swap tho...ik il need a ac from a 5.3 and most likely a LS k member for some extra room...and will stand up the rad too.
is this possible??
Old 04-20-2012, 06:58 PM
Rick Speed's Avatar
Yes 100%.. I kept AC used a stock LS1 k-member.
http://s128.photobucket.com/albums/p...t=IMG_0079.mp4
Old 04-23-2012, 03:08 PM
slomarao's Avatar
I would like to get a LM7 complete motor....run it NA for 1 yr so i get it all setup and pull it the following yr...bore it. toss in forged pistons/rods, new rings,bearings, etc.
Should i bother with the LM7 or stick LQ4/9?? I plan to have a turbo on it...will be running it NA for 1yr with a aftermarket cam,fast - ls6 intake, bigger valves, thin head gaskets.
Old 04-25-2012, 05:03 PM
slomarao's Avatar
has anyone used LT1 f body accessories with a 5.3...?? I am trying to buy as few parts as possible. Would like to re use all that i can..
I am getting:
5.3 LS
LS k member
LS steering shaft, linkage, etc
ls6 intake
f body oil pan
30lb red tops (have already)
255 walbro (have already)
harness/computer
arketsmall cam/springs/pushrods/etc
Bellhousing, Front Plate, and Input Shaft
run it NA for a yr, get it dialed in somewhat. Than pull it the following yr for forged pistons, ARP everywhere.
what else will i need...?
Old 04-26-2012, 01:01 AM
the_merv's Avatar
You will need LS accessories.
Old 04-26-2012, 08:26 AM
slomarao's Avatar
and since im a t56 i will need LS pedals correct....( push/pull ) ??
than make a few changes to the trans and get a LS style clutch??? just need confirm things before i start collecting parts.
Old 04-26-2012, 10:39 AM
the_merv's Avatar
LT pedals are the same.. Need all LS driveline parts.
Old 04-26-2012, 02:42 PM
slomarao's Avatar
but just the parts to convert will be: Bellhousing, Front Plate, and Input Shaft...??
Old 04-26-2012, 03:32 PM
the_merv's Avatar
For the T56, yes.
Make sure you check the end-play of the Mainshaft and Countershaft when you swap them pieces out.
Old 04-29-2012, 12:32 PM
Snkebait95's Avatar
Im doing this currently. Very easy if you do it all right. To sum it up, build the whole thing on the k member like youre sticking an ls1 into an ls1 car (you know, using the right parts, ie: all fbody accesories, ls1 k member, fbody oil pan and ect) get the wiring figured out, and stick her in lol
Old 05-04-2012, 10:58 PM
slomarao's Avatar
will be going 6.0 now. building an 8.8 this winter and slow picking up Lsx **** for the front mount setup i dream of at night.
Quick Reply: LT1 to 5.3 turbo swap
