Carbureted LSX forum - fouling plugs
View Full Version : fouling plugs
agarr53
04-18-2012, 05:56 PM
need help have msd 6010 on 5.7 99 camaro keeps fouling plugs holley 750 carb 70 ft 78 r truck coils
richard david
04-18-2012, 06:27 PM
How far are your air bleeds screwed out and how much timing are you running
agarr53
04-20-2012, 08:15 AM
air bleeds are 1 1\4 turns tried all 6 chips and put in custom timing 28 max still fouling plugs idles fine but try to launch off line bangs out and dies plugs are black from gas fouling
Pop N Wood
04-20-2012, 08:49 AM
How did you set your idle mixture, with a wideband, vac gauge or just set it and forget it? Holley's on an LS with a single plane intake tend to run rich unless you have modded the carb. Mine are a little over a half turn.
Could be a half dozen different things like a blown power valve, bad gasket, etc. But start with getting the idle screws right first. Obviously clean your plugs too.
Z284thgen
04-20-2012, 06:11 PM
i think my idle mix screws are close to 1/2-5/8ths of a turn out on mine with my wideband reading high 13's at idle
GNCLONE
04-20-2012, 06:29 PM
Weak spark can foul plugs too.
S10xGN
04-20-2012, 07:06 PM
Same here, my next step is to open the idle air bleeds...
agarr53
05-18-2012, 10:26 AM
im back got the carb back from carb guru reset the idle circuits and air bleeds internally put carb back on still turning plugs black four corner idle 750 dp tried setting air bleedsto1\2turn carb loaded up went back t o 1&1\2 idles fine just turns plugs black could it be bad cam senser weak coils wouldnt run rright would it
Pop N Wood
05-18-2012, 03:17 PM
The MSD box doesn't need a cam sensor to run. It has a 50-50 chance of coming up right each time you turn the key. If it starts at all then it isn't the cam sensor.
This Guide (http://www.holley.com/data/TechService/Technical/Carburetor%20Tech%20Info.pdf) tells you how to adjust your idle circuits.
bad67ls
05-19-2012, 01:37 AM
You went 1/2 turn from full seated and it loaded up,but 1 1/2 turns its fine? Something wrong there dude...
