01cherryreds10
04-18-2012, 09:31 PM
Well I made a thread about this last year, ended up using washers as spacers with the GM flexplate and Yank 3600ss.
Sent the converter to get restalled to 4000, and also replaced the GM flexplate with a Yank SFI plate.
My problem is right now with the LQ4 (NOT THE OLD CRANK STYLE) the pilot on the converter bottoms out too early on the crank and with the flexplate bolted to the crank, it's 5/16" away from the converter.
I put 3 washers in there to equal the 5/16" and used longer bolts. Now how do I go on figuring out the correct clearance that I can pull the converter out of the trans?
The best sequence I've found is crank, flexplate, spacer, bolts
Anyone have any help to give?
