what oil weight ?
what oil weight ?
I have a 5.3 with a big comp cam ls6 intake ported oil pimp, and I have the famous sewing machine noise....what's the best oil weight that I should use? Not only to quiet the sound a little bit but what's going to keep my engine alive the longest ...I live mesa Arizona and it gets up to 115° here
All 30's are not the same. There is an acceptable viscosity range for 30W at 100 degrees C. Mobil-1 is near the bottom of the range and nearly a 20W oil whereas German Castrol is near the top of the range and nearly a 40W oil. If you really want to look into this, go to the manufacturer's web sites and pull the tech sheets and look at the viscosity at 100 C and use that to help with oil selection.
