Northwest Members - first startup
mcdonald77
04-18-2012, 11:52 PM
I dont really post in here much, but wanted to share my first startup. Its a rebuilt LQ9 .030 over, l92 heads, ls3 intake and injectors with a z06 cam 204/218. Once the exhaust is done I am taking it to speed secrets for a dyno tune. I had the base tune done by tunedbyfrost.
build thread over at the s10forum http://www.s10forum.com/forum/f213/lq9-l92-heads-z06-cam-haulin-ass-jimmy-464706/
http://www.youtube.com/watch?v=poWzXN46PBQ&feature=player_embedded
tmoney223
04-19-2012, 12:57 AM
Nice man! Where did you get your intake tube from?
mcdonald77
04-19-2012, 01:00 AM
I used an 06 GTO spectre intake. It worked better then the silverado since im running it to the drivers side.
http://i1143.photobucket.com/albums/n633/jamcdonald/2012-04-18110322.jpg
smokinponcho73
04-19-2012, 10:14 AM
Sweet! that's a small cam though, planning on boost?
mcdonald77
04-19-2012, 10:42 AM
thanks!
yea I know its small, hehe. Maybe a swap in the future. It initially started as a budget build and took off from there, I really didnt think about it until the heads and cam were on the block.
No plans for boost, it's just my toy. I know there is more power to be had with a different cam. I talked to patrick G and he gave me some cam specs.
mcdonald77
04-25-2012, 10:01 PM
Anyone ever get up to the Bellingham area or are from up here? I used an ls6 camshaft. Everyone stated I should need longer pushrods and to measure. I bought a comp cams tool, read and played with it. After I while I was confident I could do it I measured and came up with 7.35 after adding preload. After the exhaust was done, it is not bad outside, but there is a lot of valve train noise on the inside. I need a second opinion and a possible hand is measuring again. I can remove and install no problems, but my measuring skills seem to lack! Shoot me a pm if you can help and I will get you my phone number.
Forgot to add, dual 3" exhaust running converters, h-pipe and dynomax vt mufflers.
http://www.youtube.com/watch?v=vThQypeocWk&feature=player_embedded
*02WS6TURK*
04-25-2012, 10:12 PM
Looks good. How's the girl that screamed and jumped back 10 feet doing? :)
mcdonald77
04-25-2012, 10:25 PM
thats the wife, sees a big chicken. she was ok after it was started.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
