Racer's Lounge - thinking about buying a 2003 sierra, high mileage. what say you?
Z28_LT1
04-19-2012, 12:06 AM
It's a good looking truck. My main concern is the 170000 mike marker on the truck. What do you guys think? I'd be paying about 4k, maybe less.
What are the more common problems with the 5.3? How comparable is the gas mileage the Trans am? should I just stay away?
AronZ28
04-19-2012, 02:02 AM
4k is a steal if it runs/drives good and has a straight body. Guys around here ask that for their 1993 Chevy trucks with the same miles in decent condition.
Black01M6SS
04-19-2012, 03:44 AM
If the truck is in good shape and the miles are the only concern I would say that is a great deal. I paid nearly 6k for my 2000 model extended cab 1500 series with the 5.3l engine and I'm very happy with it. It has almost 140k on it and everything works great. I have a friend that recently sold his and it was still running strong with nearly 250k on it. He got the truck in high school and ran the Hell out of it all the time and it never gave him any major problems as far as I know. One thing that is reassuring to me is that the engines are cheap and easy to find if something major did go wrong with it. It is a truck with a v8 so I wouldn't expect the fuel mileage to be great. I know its worse than my 6 speed Camaro when it was stock.
AronZ28
04-19-2012, 04:35 AM
Gas mileage will be WAY worse than your Trans Am, assuming its stock.
Sneakyws6
04-19-2012, 08:43 AM
I bought a 2001 Silverado Ext cab Z-71 last october. So far here is what I had issues with:
-ABS module was DOA, easy fix and it only cost $150 to have it rebuilt with 5yr warranty
-Groan when taking off from light, slip joint on the drive shaft needed lubrication
-water in headlight lenses
-speedo needle jumps, bad IP motor and easy fix
That was about it other than a slight oil leak. With the stock size 265/75/16 tires and being easy I get about 15 city and 18 highway with it. Will know soon how it does with the new tires 285/70/17 I just put on it.
Better figure in a tune up (plugs, fuel filter, air filter, and anything else you can touch) as I doubt anyone else touched it yet.
My step brother has almost 300,000 miles on his with no major issues, my dads 1996 yukon has over 400,000 miles with no issues. They are a solid platform as long as you put some time and money into them.
93M6Formula
04-19-2012, 08:58 AM
Very solid trucks, the motors are basically indestructible and miles really don't matter unless it was abused. My buddy had gotten between 18-22 MPG highway with his 04.
And if you're getting it for that price who cares if it needs a few things. You're already money ahead really.
Z28_LT1
04-19-2012, 12:22 PM
My Trans Am isn't stock it's got your run of the mill bolt ons and a smog cam.
I drove a 300 mile one way trip on the freeway. I got about 25 in the trans am freeway after I ran the numbers.
Anyone know how big the fuel tank was on the 2003 Sierra? I kinda like only spending 50 bucks to fill up the TA. lol
Added: I might get this truck. I just don't want a hidden problem like the early to mid 2000's Impala's having gasket issues, over heating problems, and being an overall PITA to work on.
93M6Formula
04-19-2012, 12:37 PM
They either came with a 20 Gal. or 35? Gal. tank I believe.
Even if something goes wrong, these trucks are extremely easy to work on.
Sneakyws6
04-19-2012, 02:31 PM
From a half tank it takes me about $60 to fill up right now. That usually has me around 250 miles on the tank.
But mine is also 4x4 with 3.73's from the factory and the Z-71 package.
