2000 ss front spring rubs on control arm bolt
Old 04-19-2012, 05:50 AM
coopdc78's Avatar
Default 2000 ss front spring rubs on control arm bolt
I bought my ss cpl years ago. It was already lowered with hotchkus spribgs all around on the original struts. I took tge tire off the other day and the driverside spring rubs the upper control arm nut.. it looks like the spring is on diffrent than the pass side. The pass side seems to be Flat on the back side and coils out about an inch to the front if that makes any sense.. if i could spin my driverside coil 180 degrees it would not rub but the way its seats in the mount i cant Anyone have this issue thanks for any help
Old 04-20-2012, 06:57 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Welcome to LS1tech!
You'll find the SEARCH function will be your best friend.
You've posted your suspension question in the gen3 external engine section.
You'll get some responses if you re-post the question in the suspension section.
Old 04-20-2012, 06:07 PM
joecar's Avatar
and post some pics.
