Wheels & Tires - PLEASE HELP!! will c5 deep dish 18x9.5 corvette rims fit my 2001 camaro?
Murphdizzzl
04-19-2012, 09:00 AM
I currently have 20x8.5 forte rims on my 2001 camaro and they r rubbing and making a really loud grinding noise i have no idea whats making it so i wanted to go down to 18 and found the c5 deep dish corvette rims 18x9.5 and i know alot of people on here have put the same size rims on here so i was wondering what i need to do to make them fit with no rubbing when i turn? thanx
Z Fury
04-19-2012, 11:38 AM
They fit without rub, assuming they are OE Wheels.
Murphdizzzl
04-19-2012, 03:16 PM
yes sir they r. and i was thinkin bout lowering it an 1'' to 1.2'' with eibech lowering spring would it rub then? and when or if i lower it i know i need a panhard bar is there anything else i need? thanx for the info
karpesh29
04-19-2012, 07:58 PM
They will fit just fine. If you lower it your going to need an adjustable panhard bar and lower control arm reolcation brackets as well. The front should be just fine as is. You might have to do some BFHing on your rear fender wells and possibly roll the fender lips but thats the extent of modifications youll need to do to fit an 18x9.5.
BOBS99SS
04-19-2012, 08:16 PM
Karp has posted the correct info, and imo i would go 18x10.5 on all 4 corners, they look a hell of alot better than the just 18x9s all around,check the post your c5dd thread and you will see what im talking about
Murphdizzzl
04-19-2012, 08:31 PM
do i roll the fenders on all 4 corner or just the rear?
and to bobs99ss- wouldnt they rub up front when i turn if i went with 10.5 and if so how do u fix it, spacers or what? thanx for the help so far!
karpesh29
04-22-2012, 03:43 AM
Just the rears, fronts can not be rolled as they are plastic
Murphdizzzl
04-22-2012, 07:57 PM
kool and the rims im lookin at r 18x9.5 with an offset of 58 and the back spacing is 7.53 if that matters. will i need a spacer for the front or what will i need to make it fit?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
