Small Block & Big Block Chevy Specific - lt4 hot cam in a non roller pre 80 bloc?
king-918
04-19-2012, 11:42 AM
I have the block and cam but the cam sprocket does not match up please help
king-918
04-19-2012, 11:44 AM
I have the cam too,, already converted everything else I thnk
king-918
04-20-2012, 03:26 PM
Any help?
xx_ED_xx
04-20-2012, 06:02 PM
Pictures, year etc would help
They sell conversion lifters you will probably have to use a cam button since you cant retain it in the block like they do in the newer blocks
king-918
04-23-2012, 07:48 AM
Will post as soon as possible, but the problem is the car sprocket is different
king-918
04-26-2012, 11:06 AM
Still have not had the time to post pictures but I have fixed the issue. Pre-roller blocks, lt1-lt4, vortecs have different cam sprockets on the timing set
king-918
05-28-2012, 04:25 PM
http://www.facebook.com/photo.php?fbid=758641794314&set=a.726578933544.2126438.71302473&type=3&theater
king-918
05-28-2012, 04:39 PM
http://www.facebook.com/photo.php?fbid=725871566114&set=a.726578933544.2126438.71302473&type=3&theater
http://www.facebook.com/photo.php?fbid=724239312164&set=a.726578933544.2126438.71302473&type=3&theater
http://www.facebook.com/photo.php?fbid=710546153364&set=a.726578933544.2126438.71302473&type=3&theater
http://www.facebook.com/photo.php?fbid=702054301104&set=a.726578933544.2126438.71302473&type=3&theater
http://www.facebook.com/photo.php?fbid=662523855434&set=a.726578933544.2126438.71302473&type=3&theater
http://www.facebook.com/photo.php?fbid=662523391364&set=a.726578933544.2126438.71302473&type=3&theater
http://www.facebook.com/photo.php?fbid=653988679994&set=a.726578933544.2126438.71302473&type=3&theater
MikeFSKSpeed
05-28-2012, 05:58 PM
The factory roller cams have a smaller bolt pattern. You need an 87-Up timing set. You also need retro fit lifters ($450+)
I have everything you need if you want to make the swap, pm me
king-918
05-28-2012, 06:30 PM
http://sphotos.xx.fbcdn.net/hphotos-ash3/s720x720/550852_758641255394_71302473_33757383_119349928_n. jpg
http://sphotos.xx.fbcdn.net/hphotos-prn1/s720x720/11801_758641794314_71302473_33757386_1730944576_n. jpg
http://sphotos.xx.fbcdn.net/hphotos-ash3/s720x720/522756_725870308634_1538067613_n.jpg
king-918
05-28-2012, 06:33 PM
thanks but I have a set. even answered my own question but i figured i might as well post pictures and updates so people will know they did not waste their time with helping me. but thanks really
king-918
05-28-2012, 06:35 PM
also i found out that you can not use a LT4 timing set because of the water pump
CNC BLOCKS N/E
05-28-2012, 10:24 PM
You also need a place to put the retainer plate!!! Not going to work the older blocks.
king-918
05-29-2012, 08:06 AM
I am bit confused about what you mean can you explain?
CNC BLOCKS N/E
05-29-2012, 08:10 AM
Later blocks use a retainer plate that goes between the cam and the timing gear to keep the cam from moving front to rear.
king-918
05-29-2012, 06:37 PM
I have a cam button to control thrust
CNC BLOCKS N/E
06-02-2012, 03:24 PM
With out the retainer plate your cam will be pushed back in the block to far.
king-918
06-04-2012, 10:47 AM
I kinda hate text becauce of the lack of emotion but thanks really for all your help and knowledge with this build.
I have found a great and cheap workaround for the issue. So you anyone can install a factory roller in a nonroller block. I have to post so others will know
http://forums.corvetteforum.com/c3-tech-performance/2489470-bee-jays-lt4-hot-cam-hydraulic-roller-conversion.html
king-918
06-05-2012, 08:13 AM
http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LPE&Product_Code=L200105000&Category_Code=C30
