Drag Racing Tech - Drag LT1 pan
fex77k
04-19-2012, 12:49 PM
I need to get a pan with good oil control and at least a functional kickout. I'm running a 3qt accumulator and a tilton starter. I was looking at the Stef's 1031BC, but I'm not set on that pan yet. It's going on a 388 LT1 with motorplates.
355z28
04-19-2012, 02:42 PM
Give Kevko oil pans a call. He's a great guy to work with and will custom a pan to whatever you need.
Austin
joelster
04-22-2012, 11:16 AM
How much of a kickout do you need? I run a Milodon 30909. It will clear a 4" stroke crank with zero fitment issues. Both sides are slightly kicked out at the very bottom. It can hold 6qts.
http://static.summitracing.com/global/images/prod/large/mil-30909_w.jpg
fex77k
04-23-2012, 02:14 AM
The Stef's has a 12" long sump, 2" passenger side kickout, 4 1/2" on the front 8" or greater for the sump depth. I have been looking at Milodon as well.
sweetbmxrider
04-23-2012, 10:51 AM
Does that pan have a trap door too? The one I got did.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
