Gears & Axles - omfg ready to sell this car leaking rear end
wildryno 69
04-19-2012, 03:12 PM
i have literally worked on this rear end at least 8 times since summer of last year. 98 trans am 10 bolt that keeps leaking gear lube either from the pumpkin seal(fixed) or from the pinion seal and just had gears put in not to long ago and it is still doing it,
MUSTANGBRKR02
04-19-2012, 03:18 PM
Stop
Putting
Money
In
The
Ten
Bolt
babbage1109
04-19-2012, 03:20 PM
Get a tube of black rtv and gob it all over
guppymech
04-19-2012, 06:44 PM
Sometimes gear lube will work its way up the pinion splines and come out from under the pinion nut and washer. When this lube gets slung it can appear to be from the pinion seal. If this is the case, disconnect the driveshaft from the pinion yoke and clean the pinion nut, washer and yoke. Apply a fillet of rtv around the nut and washer to the yoke and let it dry before driving the car.
Whenever the pinion yoke is removed and reinstalled before the washer and nut are installed it is good practice to fill the countersunk area of the yoke under where the washer goes with some sealant and then install the washer and pinion nut. This will prevent gear lube from coming out from the pinion splines.
216StealthSS
04-19-2012, 06:58 PM
Stop
Putting
Money
In
The
Ten
Bolt
:judge: believe me, i am on my 2nd one... just swappin the whole thing out and bye bye GM diff!!!!!
guppymech
04-19-2012, 06:59 PM
Forgot to mention above that the sealant for UNDER the pinion washer and nut should probably be anaerobic sealant or a two part chemical cure type sealant.
LS1_Sean
04-19-2012, 08:47 PM
^x2 otherwise oil leaks through the pinion splines.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
