Best tire size/brand for Weld 17x8 front wheels
What is Best tire size and brand for Weld RT-S 17x8 front wheels. I have M&H Racemaster tires on my rear Weld RT-S 15x10 rear wheels. The car is a 98 LS7 TA strret/strip car. The car will be driven mostly on the street so I decided againt skinnys for the front. I am also trying to match up the tread pattern with the M&H Racemasters. Any suggestions?
IMO, the narrowest I'd go with is a 225/50/17 (25.86"), Cooper Zeon RS3-S
or a 235/50/17(26.25") Nitto NT NeoGen ZR the tallest.
The widest I'd go is a 245/45/17 (25.68") Cooper Zeon RS3-S
I also picked these in considering that they would have a some what similar look to the tread pattern.
DTD has all of these.
IMO, the 225/45/17 is to short, the 225/50/17 will look better since it'll fill the wheel wells better. The only down side I could possibly see is that the 225s might look a little narrow on the 8" wide wheels. If that bothers you any at all then I'd go with the 245/45/17, if you still prefer a taller tire then go with a 235/50/17.
