twin turbonetics 11533 thoughts
I have been looking at ideas on twin turbos for my 408. It currently has a f1a on it and looking to pull it off this weekend. I have been looking at turbonetics hurricane turbos because they are pretty inexpensive. I am wanting to do a twin ls3 manifold setup like the other thread on here. I was looking at the 11533 turbo in particular. Its a t4 flange with a 72 compressor and 68 turbine wheel. It has a .81 ar on the exhaust. Would using a pair of these get me 800 hp on 12psi of boost on a built 408 worked l92 heads? Would this be a good spooling turbo that where boost would come on stong at 4000-4500 rpms? I want room to grow obviously and would eventually turn it up to 18psi and try to make a **** ton more power. Would I be better off going with the 11226 with the 66/65? Here is the link to the spec page. Tell me your expert thoughts. Thanks, Josh
http://www.turboneticsinc.com/turboc...-turbochargers
A single 76mm will make 1000 fwhp on a 370 with the correct turbine.
Twin 61's will get you 1300 fwhp. About the same as a PT88H.
That's 8 sec power.
twin 70's are usually on drag cars or 427+ cid.
Check Nelson Racing Engines site.
He has a 388 LSX w/ ported L92's that makes 1400 hp w/ twin 61's.
And a 427 gen1 w/ twin 72's that makes 1500+ - dig in the videos and you can find it in a yellow? 2nd gen.
Might see if he'll sell you a cam.
What are your plans?
That's 8 sec power.
I'd go 6162 or 6262's for twins on a 370. Not a fan of 4" crank in iron block with boost.
But I bought a GT4788R yesterday instead.
You'll have plenty of fun with the twin 66's on your 408.
If I'd bought a sleeved LS2 block instead of the NA 416 I got (in hind site) it's how I'd go.
