Conversions & Hybrids - Clutch pedal bracket for ls1 swap into a 69 Camaro
ryanater
04-20-2012, 12:08 AM
So I know there is a bracket you can make to use your stock clutch pedal with the clutch master cylinder that came from the donor car. I keep seeing this drawing floating all over the internet but have yet to find one that I can actually read.
Does anyone have a clearer version of this drawing or can tell me what the dimensions are?
http://i133.photobucket.com/albums/q75/f150x05/pedaldrawing69.jpg
ryanater
04-20-2012, 06:34 PM
Anyone?
1slowta
04-20-2012, 06:51 PM
http://www.hotrodlane.cc/New%20LS%20Links%20Page/LS%20links%20page.html#installs. Then click on S&P installs a LS-2 into a '69 Camaro.
ryanater
04-20-2012, 06:58 PM
I owe you one! Thanks! I've been looking for that forever.
72_nova
04-22-2012, 10:46 AM
I just cut the end of the MC rod off then cut about 2 inches off the rod and welded it back together. then drilled a hole in the brake pedal to that the rod actuates in a linear motion...seems to work great so far.
jmoli42572
04-22-2012, 09:49 PM
Speed tech sells the parts to shorten the stock one and make it ajustable I think it cost $25
