Suspension & Brakes - Need to raise just the front of the car
camarodude87
04-20-2012, 07:07 AM
hey guys,
Got an issue when I put my weld rt's on. My Y pipe smacks the driveway evertime I pull into it. I had the front dropped what like 1 1/4 of an inch. Has anyone on here ran the drag bags up front? or should I run some jegs spring spacers in there, OR just throw in the stock springs back up front?
much thanks,
Ray
jetaws6
04-20-2012, 07:27 AM
I have strange coil overs on the front of my car so I was able to adjust them up when I put my skinnys on. Worked like a charm
BMR Sales2
04-20-2012, 07:55 AM
We have shock spacers that sit between the shock and the lower a-arm that you can use to raise the car up some if you need to. They will raise the car right at a 1/2" and are easy to install.
camarodude87
04-20-2012, 09:24 AM
do I have to de-compress the spring any
4WOFURY
04-20-2012, 12:04 PM
No, they install the mounting point on the bottom of the shock to the lower a arm.
