A-body oil pan??
A-body oil pan??
Ok I've read over every A-body swap thread and damn did that take for ever . My buddy and I are both doing A-body swaps at the same time and we would like to know best stock pan to use for price and fitment... I've read CTS V or LH8 pan but it seems the LH8 pan may hang to low. CTS pan is over $200 shipped on Ebay.
Can someone give me some measurements on both to how low they will hang past cross member? Also which mounts to use per pan??
Any help would be SUPER appreciated if i was close I would give ya a smoke and a pancake lol!
Holley pan. AutoPartsway.com for $319.00 shipped to your door.
Nice ride thunderstruck!
99vette, how much room is the passenger head from the fire wall? Im wondering if the ctsv pan moves the engine a little more forward than an fbody pan? It may give a little more room for the tranny. The fbody gives about an inch or less from the fire wall to the passenger head IIRC.
I have a lq4 in a 71 el camino and I read a ton of post's about pans like you did and decided that I would use the f-body pan because a lot of people said it would fit. I could not figure out how to make it fit without notching my frame. You don't have to notch much and once its in it fits great. Definitely doesn't hang below the frame. The only way I could see it fitting with notching the frame is if I got rid of the fiberglass case that covers my heater and a/c stuff. I tried notching the fiberglass first but I was still about 3/4'' shy of getting it to slip in. If you are a good welder or know one its not bad notching the frame. I over killed mine when putting it back together by putting a 3/4'' piece of plate steel inside the frame fro strength before boxing it back in with 5/16'' plate steel.
I tried chopping up a truck pan with no luck on fittment.
Bought one of the first Mast Motorsports pans and it eliminated my engine placement headaches in my 64 chevelle. Without the mast pan I would have had to cut the tranny tunnel and switched to a car intake. Only thing I don't like about it is that I cannot install the engine and tranny together, which I could when the engine had the truck pan bolted to it.
I set my engine with the truck pan on, and then I put the CTS-V pan on when I cracked the truck pan and it fit with room to spare. I can actually slide my hand between the head and firewall. I don't have any pics of that but I don't have AC either. NonAC car.
