Generation III Internal Engine - Advice on crank
View Full Version : Advice on crank
Ls sn95
04-20-2012, 05:57 PM
What crank to run in my lq4 to support I've seen and heard of plenty of guys making this power on the stock ls1 crank it's goin to be spun by a F1R at 20 25 psi is that much boost goin to put to much pressure on the stock crank,if so what crank do I go with
ANTICOP RAM AIR
04-20-2012, 06:00 PM
same crank casting.. LS1 is drilled in the center and balanced for a different rotating assembly... both cranks are good to well over 800 hp... Id see the only advantage being with the LS1 crank but only cause its probably a little lighter and can rev higher... if you plan to really wind it up...
Ls sn95
04-20-2012, 06:08 PM
Well this is my first ls style motor so I can put the ls crank in the lq4 the plan is to go to a 408 CID will this work
