12 Second Club - High twelves...
View Full Version : High twelves...
LASTOFTHEBREED02T/A
04-20-2012, 06:03 PM
Stock transmission,
http://youtu.be/juCD5ZDtraA
I was expecting to do better at the track this day... Got a best of 12.93 on street tires.
My trans was on the down side, broke next day when i took it out for a spin.
Since then, I added a below, lid, cut out, Nittos 555, Tb bypass, trans cooler, Debaffled the scoops, and As of right now in the shop getting a built trans with 3800Vig Put it in.
I hope to smoke my buddies 480hp termi... Hope for low 12's high 11's
projectX
04-20-2012, 06:24 PM
What mods did you have when you ran? Maybe I am reading this wrong.
LASTOFTHEBREED02T/A
04-20-2012, 06:36 PM
I had 224 cam, springs, pushrods, gutted catz, cut out, shorty headers, street tires, ls2 timming chain, ls6 oil pump, and not sure if lid... this vid is from a nov dec time frame.
now it has all that plus, DR's, Lid, K&N, debaffled scoops, bellow, TB bypass, trans cooler... Built 4l60e and stall is being done as we speak.
Sorry for all the confusion...
Just think i had enough hp to be closer to mid 12's
LS1rob00
04-20-2012, 07:39 PM
If the Termi was the one you ran there it's not gonna happen with him having a 120 trap lol. Hopefully the car runs better with the trans refreshed and some DR's out back.
LASTOFTHEBREED02T/A
04-20-2012, 07:44 PM
He ran .2 sec faster than me... I will also have a 3800 vig in the trans
projectX
04-20-2012, 08:51 PM
Well, you have a nice set up and tasteful mods so I say post a video when you get everything done. Curious to see times.
LASTOFTHEBREED02T/A
04-20-2012, 10:24 PM
Will do... And should have a footage of a retune dyno, It will be a few hp loss im sure.
Mean87SS
04-20-2012, 10:30 PM
Better drive well... 120 MPH is moving be seems like he cant drive?
LS1rob00
04-21-2012, 04:04 AM
I don't think you get it, he out trapped you by 10mph lol.
Just seems like he needed some help in the driving/traction dept. That car should be running 11's easy with that trap.
The Stall will definitely help your ET a lot though. You'll probably run mid/low 12's if everything goes well.
LASTOFTHEBREED02T/A
04-21-2012, 12:27 PM
Soon we will find out i guess... But he was also on street tires with newly intalled 373's. He is very fast, specially when he hits the 100 shot.
LASTOFTHEBREED02T/A
04-30-2012, 07:20 PM
WTF!!!
So i went to the track after breaking in the trans and stall, with my new nittos 555r's.
I thought these where suppouse to hook as everyone told me they would.
My times 16.1 et with a 2.1 60//// 15.7 et 2.3 60/// And the one pass i did hook i let out thinking i was gona keep on spinning. 12.6 et 1.9 60 @ 106.
I dont get it, does the stall make me loose Trap speed? When stock i was at 110 trap...
Im Pissed!!!
I know I wont see much Improvement as times get a lil faster than stock, and not hoping to see 11's but atleast a low 12.
What em i doing wrong? I have to admit, its a totally different car after the stall. So if you have a stall in your ride, please shime in, Thanks.
Goat2NV
04-30-2012, 08:01 PM
Did you get your tune adjusted for the stall?
LASTOFTHEBREED02T/A
04-30-2012, 08:06 PM
yes shift points are at 6K... I know my exhaust is killing me becuase its stock, except the shorties, but damm. My 60 SUCKS!
LS1rob00
05-01-2012, 03:33 AM
Well first off the pressure has to be right on the Nitto's, I run the same tires. What did you have the pressure at?
Also, you have to do a really good burnout with them. They like to be heated up a lot in order to hook.
I'm thinking those two things may have been your problem, but chime in and let me know.
BOBS99SS
05-01-2012, 04:40 AM
I wouldnt even call that an exhaust, the stock shortys are just as good as aftermarket,
LASTOFTHEBREED02T/A
05-02-2012, 07:25 PM
You confuse me...
I know shorties are pos compared to LT's.
WhiteKnight '01
05-02-2012, 07:30 PM
120MPH and only a 12.7 for the Cobra!? WTF!!! lol
What happened to your transmission? How many miles did you have on it?
And LOL at the announcer just calling it a Firebird and a Mustang. Big difference between a Mustang and a Cobra and a Firebird and a Trans Am.
LASTOFTHEBREED02T/A
05-03-2012, 06:58 PM
lol, yes the announcer is a dumb ass. New guy!
My trans had 127,xxx miles when it went out, the next day after this vid.
Just dissapointed with my times and trap now, WTF is what i also said.
murphinator
05-06-2012, 09:02 PM
trap speed tells you if you are making more or less power on a given night as well as potential for et if hooked up well/driven well.
a BIG factor that can drop traps drastically and kill et's is density altitude , learn what density altitude is and start paying attention to it - there are density altitude calculators on the web and many can link to local track weather conditions.
your in Texas so its hotter than heck I am imagining , up here I have seen traps drop by that much if its 60 instead of 45 for example but density altitude(DA) also looks at track elevation and relative humidity .
up here good racing weather is -500 to -1500 below sea level DA , I am guessing where you are 1000 to 1500 above sea level would be pretty good but ask around and if your looking for personal best et's go when weather is favorable to PB's - expect the track to be busy , it usually is on good weather nights
