Fueling & Injection - How to reove fuel pressure regulator on an ls1 plastic tank?
penguinpanda0
04-20-2012, 07:02 PM
Putting an ls1 plastic gas tank in my 87 IROC, I need to remove the fuel pressure regulator to get it to work with my L98, as I dont have the funds to complete my ls1 swap. I'm pretty lost, anyone wanna provide some insight?
Ollie8974
04-21-2012, 07:57 AM
The fuel pressure regulator is mounted in the fuel pump module,
push up on the spring clip the regulator will fall out.
Mr. Fuel Pump
04-21-2012, 10:37 AM
Your question begs another...how it the heck is a ls1 vintage plastic tank going to fit into an 87 IROC? I would think no chance, but crazier things have happened.
QwkTrip
04-21-2012, 06:28 PM
It slips right in and uses the same straps. 3rd gen and 4th gen share the same underbody and suspension from the rear seat on back. I have one sitting in my '89 Firebird right now. Although, I'm keeping the fuel module in tact. Why remove a perfectly good regulator just to add one in somewhere else?
penguinpanda0
04-21-2012, 07:34 PM
The L98 runs on a lot lower pressure than the ls1 does. Therefore, I need to remove the fuel pressure regulator in the new tank such that the one on the fuel rail of the L98 will function. I got it out, do I need to plug the hole that regulator connected to?
QwkTrip
04-21-2012, 08:04 PM
Sorry, I assumed you were doing an LS1 swap.
No, don't plug the hole. That is the fuel return back to tank.
Ollie8974
04-22-2012, 08:05 AM
No, Do not plug the hole where the regulator was. That is the fuel return to the tank.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
