Generation III Internal Engine - MLS Head Gasket Sealant?
View Full Version : MLS Head Gasket Sealant?
badazz81z28
04-20-2012, 10:07 PM
When I took my heads off I noticed this bluish oily residue on the heads. Since the MLS gaskets have what appears to be black O rings, do they need to be lubricated prior to installation?
djfury05
04-20-2012, 10:19 PM
No.. clean the block's deck surface off really well. For the final wipe I use just rubbing alcohol and let it dry. MLS gaskets can go on dry no issues.
batboy
04-20-2012, 11:06 PM
The last head gaskets were probably graphite. Make sure you clean up all that gunk real good.
badazz81z28
04-21-2012, 10:30 AM
No, they were MLS just like the ones I bought. This is a 2004+ls1
NVR_SPDS
04-21-2012, 11:06 AM
I just recently installed GM MLS gaskets, and although Ive heard you can use the copper spray, I installed everything clean and dry. Worked out great, no leaks, no issues.
SF 1HOTLS1
04-21-2012, 11:20 AM
do MLS gaskets leave gunk on the block that needs to be scraped off? or do they just come right off the head clean?
JS01
04-21-2012, 11:21 AM
They leave a thin black rubber/sealant like compound on the heads and block. It must be scraped off well before re-installing the heads.
badazz81z28
04-21-2012, 11:42 AM
Nope, not really. Its just steel with rubber type O rings around the sealing areas. Mine is super clean, no scraping will be required for me.
This is what it looked like after I pulled the head. You cant really see anything, there is just rubber looking material here and there around the cylinders and bolt holes.
http://i19.photobucket.com/albums/b151/badazz81z28/ls15.jpg
SF 1HOTLS1
04-21-2012, 11:55 AM
looks clean to me! i figured since its steel there shouldn't be much to scrape.
