Wheels & Tires - c5s rubbing
View Full Version : c5s rubbing
graysonsdad47
04-21-2012, 02:02 PM
i recently bought a set of gm c5s that came with a 265/40/17 in the front, the only problem is they rubbed bad and now i have to get new tires. I was wondering if i got a 275/40 on the front would i still have this problem, and do i need to get a spacer of some sort?
the rear are 295/35/18 and they are great, and only rub when i go over bumps or turning hard...
any input would be greatly appreciated
VinR1
04-21-2012, 05:07 PM
Where do they rub?
graysonsdad47
04-21-2012, 11:48 PM
they rub on the inside top part of the tire...
buellxb12s
04-22-2012, 09:33 AM
That wheel came a 245 45 17 front and probably wouldn't rub if you had that on it but I bet will rub with a 275 and probably worse than with the 265
desertLS1
04-22-2012, 11:41 AM
You'll need spacers man.
graysonsdad47
04-22-2012, 08:07 PM
do you know what size i should go with...
