PCM Diagnostics & Tuning - What's your Cammed LS1 M6 idle at ?
99Bluz28
04-21-2012, 06:13 PM
I'm just curious, what's does your cammed ls1 idle good at after it was tuned?
Let me also know what size cam you have and it's LSA.
Mine was set to 950rpm by my tuner, and my cam is a 227/231 111+2 lsa with TPiS 90 intake, 66cc AFR 205's, LT headers, an stock 3.42 rear gears.
I would love to be able to at least drop it to 850rpm!
heymoej
04-21-2012, 06:16 PM
a little over 1100rpm..........
99Bluz28
04-21-2012, 06:19 PM
What size cam do you have, what lsa is it on?
heymoej
04-21-2012, 06:44 PM
my cam is a 240 .630 single pattern on a 114LSA.
my 243 are also ported,if that matters to your idleing question.......?
Blu99T/A
04-21-2012, 06:52 PM
230/232 .613/.598 110LSA idles at 950. I tried to drop it, but it created other idling issues for me, specifically when coming to a stop.
SladeX
04-21-2012, 10:56 PM
tr224 112lsa 900rpm
230/230 117lsa 900rpm
230/230 115+2 900 l92 block 379ci, ls6 intake 5.3 heads stage 2.5
Just tried 750rpm and 800 rpm. 750 brings in a very slight cam lope, and 800 is just down right quiet. I think I'll keep 800rpm since it has a nice bass tone to it.
Schantin
04-22-2012, 08:23 AM
CC 228/232 .600/.601 111LSA. Cold idle 1100RPMs. Hot idle 950.
Hemi2Slo
04-22-2012, 01:32 PM
218/228 110LSA, 750 rpms running temp.
Just tuned one this weekend 228/228 112LSA, sounded best at 850 running temp so left it there.
Floorman279
04-22-2012, 01:34 PM
236 238 112 lsa......right around 800 rpms
bene
04-22-2012, 03:43 PM
EPS cam 222/226 LSA 113 with stock 243 heads, idle set at 700 rpm. No bucks, no surges and AFR is perfect.
99Bluz28
04-22-2012, 04:02 PM
Cool, keep them coming, the more reply's the better!
atrain59
04-22-2012, 04:08 PM
Tsp 228R cam, start up idle is set at 1000 and warm idle is set at 750
Carter01
04-22-2012, 04:29 PM
tsp torquer 2 on a 112lsa 850rpms
99Bluz28
04-22-2012, 08:11 PM
What's the LSA 112,114,... ?
99Bluz28
04-26-2012, 06:12 PM
Guys keep them coming, the more reply's the better!
Ryans99ls1
04-26-2012, 09:03 PM
230/230 .613/.591 111+2 LSA idles set at 800 or 850, cant remember exactly
i6overboard
04-27-2012, 10:41 AM
Bullet 226/230 114lsa .600/.600 set at 750, has problems coming to stop... need to up it to 850
cyipher
04-30-2012, 04:46 PM
238/242 - 950 rpm
RoyWS6
04-30-2012, 05:37 PM
875 rpm.... EPS 234/236 .612”/.612” 112LSA +4.
Works perfect with my setup.
Scoggin Dickey
04-30-2012, 05:42 PM
My personal C5 is a stock cube LS1 with a 238/247 on a 114 and it idles perfect at 850rpm.
There is no reason a cam as small as the OP has should have to idle at 950rpm.
jmm98LS1
05-01-2012, 07:51 AM
246/254 .613"/.613" 110+4 hot idle is 1000rpm (sound clip in sig)
VandykeT/A
05-09-2012, 09:07 PM
MS4-900-850ish.
Predator
05-10-2012, 02:24 AM
TR224/ 112 M6, 825 rpms.
slammedc5
05-10-2012, 03:46 AM
240/240 .630. 113 lsa. Underdriven balancer/pulley.
900 rpm
SSpdDmon
05-10-2012, 02:49 PM
Mine is usually set to 850 or 900. Cam is a Vindicator - so 24x duration @ ~600 lift.
Just for fun, we dropped the commanded idle to 600. My tune held up it's end of the deal. The alternator wasn't too happy though. :lol:
http://www.youtube.com/watch?v=jiK6YIZEcXo
bayer-z28
05-10-2012, 08:17 PM
900 when warmed up.. 850 cold. PatG tq cam, 102 and UDP.
dm79
05-13-2012, 04:43 PM
238/244 605/612 114 lsa. i have my idle set at 900. still playing with my idle tune so ill see if i can drop that some. stock cube, ls6 intake 80mm tb, all supporting mods
98Zheadsncam
05-14-2012, 11:10 AM
234/240, 112lsa - 870rpm.
NoGo
05-14-2012, 11:48 AM
224/232 114 LSA.... (something like that).
It idles at 800 then up to 1100 then back to 800, then back up to 1100, then back to 800..... j/k. It idles at 800 when hot.
Depends on the cam and setup. Some setups are just cranky and need to be idled a little higher.
SSpdDmon
05-14-2012, 02:50 PM
:lol:
00shortbox
05-14-2012, 08:08 PM
Cold start mine is around 1100, hot is 950rpm, I wouldn't mind it down around 800-850. I have a nelson tune. LS6 with a 220/224 .575/.575 on a 112LSA.
Wicked94Z
05-15-2012, 06:30 AM
I'll play! 267/272 .695/.698 110lsa. Likes a 980 rpm idle but no lower makes 4.5" of vacuum.. 1300 at cold start, runs E85 that's kind of grumpy cold.
Compressor Surge
05-15-2012, 03:46 PM
Comp 228/230 .571/.573 112LSA
LQ4
800 rpm warmed up
Nemesis350
06-07-2012, 11:29 PM
just felt like adding to this... please don't make fun of my cam LOL
T-ReX v.2 - 242/248 - .608/.612 - 110 lsa , cold start around 1100, at temp around 950. I'm thinking about dropping idle a little
redtail2426
06-09-2012, 08:38 AM
i have a 228/230 .571 .573 112 and right now i have mine set at 850 hot and it runs perfect.but with the new rolling idle tables in hptuners i could probably get it to idle perfect at 650,i might play around it and see,but im pretty confident in it working great
Eddie 70
06-10-2012, 08:52 AM
G5X2 -232/240 .595/.609 112+4 Stock displacement LS, Melrose headers, 2.5" duals with x-pipe
Right now the idle is set at 925, still learning to tune the thing.
cyipher
06-10-2012, 10:11 AM
I reset my idle to 850 and my car seems to like that better coming back down to idle when stoping didnt surge once, it only surged once in a blue moon before that.
Leeroyws6
06-10-2012, 10:24 AM
298/301 .595lift 1000rpm cold about 900 normal operating temp. oops mines an a4.so thats in park. in gear its about 850-900
