Fueling & Injection - Fitting type at fuel filter?
View Full Version : Fitting type at fuel filter?
QwkTrip
04-21-2012, 06:21 PM
I'm trying to build a fuel system for LSx swap into older car. Using the Camaro LS1 fuel filter but I don't know what type of fitting is used on the threaded end of the filter. Anybody know?
Here are two examples. I'm guessing it is one of these styles?
http://i1137.photobucket.com/albums/n515/QwkTrip/4770d03c.jpg
QwkTrip
04-22-2012, 01:38 PM
Nobody knows? I think it is the one on the right side of picture.
QwkTrip
04-24-2012, 07:10 AM
Somebody here has changed a fuel filter and seen the fitting. Is it the one on the right, or not? I've ruled out the one on the left.
MeentSS02
04-24-2012, 08:46 AM
Assuming it is the same as the return line on the t-block of the f-body fuel system, it is a 14mm x 1.5 o-ring fitting (Russel Part # 648070 [14mm x 1.5 O-ring to -6AN] is the correct adapter for the t-block to convert it to -6AN). So the fitting on the right in your picture.
QwkTrip
04-24-2012, 06:09 PM
Good, so I do have the right style then. Thanks!
MeentSS02
04-24-2012, 07:59 PM
Yes you do.
MM98
04-25-2012, 11:53 AM
I thought the feed line had 16MMx1.5 nuts from filter to t-block & the return was 14MM X 1.5?
MeentSS02
04-25-2012, 12:03 PM
That could very well be the case...since I no longer have my Camaro, I can't verify the sizes. I know for a fact that the return is a 14mm x 1.5, but never had to replace anything on the feed side.
QwkTrip
04-28-2012, 03:31 PM
Thank you.
QwkTrip
04-28-2012, 08:44 PM
Just in case anybody pulls this up in a future search, the parts to adapt to -6AN are the TPI fuel rail adapter fittings, ACCEL p/n 74730. Earl's has similar parts.
