How does this ride height look?
26" in the front, 27" in the rear. I'm hesitant to lower the rear any more, I have 3" of compression travel (really less, the tire touches the outer fender before i get to frame). To get lower I'd have to run narrower tires or more negative camber.
I've seen your car, Austin Auflick's, SHovV's car, and those wide meats are great. In this case, for me, wide isn't always better.
I can pick wide and rake, or less wide, lower and more level (without adding more work of course). I say I can add camber, but if I did that I'd probably hit the inner fender well. There's just not a lot of room to play with.
I could run Nitto 315's probably and have fewer issues.
