Wideband O2 Extension Harness
I've got a wideband setup from Innovate that uses the Bosch LSU4.2 sensor. I'm going completely through my truck's harness to make things as clean as possible and I'd like to mount the wideband controller inside the cab. So, does anybody make a wideband o2 extension harness?
Moderator
I've never seen anything about it, but I'd guess Innovate
would be the place to start. Their LM-1 harness looks
custom (DIN on one end). I would bet that you could
cobble an extension there with some fat 8-wire cable
and not hurt anything; anywhere between the meter
and the far end connector that receives the LSU4 ought
to be fine, it can't be part of the oxygen path (if any)
if it's on the other side of the connector from the sensor.
