Nitrous Oxide - Dry shot questions
View Full Version : Dry shot questions
01SOMZ28
04-21-2012, 11:25 PM
How quick does the MAF react to the nitrous? I've always ran a wet setup but I have a new idea and it requires a dry setup.
I've seen plenty of people spraying 100-125 through the MAF so i'm assuming it will support that easily. What about a 150?
What would the limit be for the MAF on a dry shot?
My fuel system is a racetronix pump and 39# injectors from an '03 Cobra.
SCott5
04-22-2012, 09:42 AM
I have seen people do it, but I have no experience with anything bigger than a 125, I have only went to a 125 shot and now switching over to a wet.
wreckwriter
04-22-2012, 10:31 AM
I shoot 175 dry into my Procharger inlet pipe before the intercooler. Reacts pretty much instantly, runs very strong. I have 65 pound injectors, running about 93% with that shot. I think it mostly depends on tuner skill to get it to work right.
karpetcm
04-22-2012, 12:24 PM
I ran 125 dry for a few month no real issues other then the nozzle was to close to the maf needs to be far back to fog up properly and orientation. You have enough fuel to do a 150 dry the tune needs to be good and ull be fine.
hardcore
04-22-2012, 12:41 PM
I run a big Dry shot 225-250 I never had any luck with spraying though the MAF and I don't recommend doing it..
I have a dedicated tune that adds the need Fuel only when I spray
01SOMZ28
04-22-2012, 01:40 PM
I won't be using a nozzle, i'll be using this http://www.nitrousoutlet.com/catalog/product.asp?category=23&section=88&group=284&product=1210
Carter01
04-23-2012, 09:01 PM
Hardcore's setup runs really well. Seen it in person many times.
01SOMZ28
04-24-2012, 03:37 PM
How would i add the extra fuel if it isn't being sprayed through the MAF?
RedRocketZ28
04-24-2012, 04:06 PM
FWIW I ran the HALO bar on my 00 SS. I do not condone doing what I did as it wasn't the safest way to go about it. Anyway, I ran a 100 shot and pulled timing with the resistor mod. My cam only tune had fairly low timing to begin with for some reason, but the car picked up well on the dry shot. The halo bar will not hit real hard but it comes on nice. Saw nothing to be concerned with while monitoring the hit. The MAF did a decent job on compensating for what I had.
I did not have the balls to run over a 100 shot without a proper tune though, which I am sure yours will be setup for.
SCott5
04-24-2012, 07:21 PM
Are you saying it didnt hit as hard as a nozzle?
hardcore
04-24-2012, 07:41 PM
A quick and easy answer... I change the commanded air fuel ratio down to 9.38, when the No2 hits it runs up to 12.4..
there are a few ways to trigger that, I use a IAT tricker..
More info here http://www.ls1gto.com/forums/showthread.php?t=332896&highlight=
RedRocketZ28
04-25-2012, 06:50 AM
Yes. It didn't have that instant "hit", it was more gradual.
01SOMZ28
04-25-2012, 08:58 PM
I must say, i do not understand any of that lol
