Generation III Internal Engine - lq4 questions
MY_2K_Z
04-21-2012, 11:30 PM
ok so i totalled my 04 silverado with an lq4 so i pulled it to build it and swap into my 2000 camaro. it had 160000 miles all from me on the highway. i only ran fully synthetic oil and babied it. wen i pulled the heads i was very pleased to see that it looked amazing still has the factory cross hatching. i will post pics soon to prove it. now the question i think i might just do bearings and rings no boring would that be a good idea?
mark21742
04-22-2012, 12:12 AM
You will want to run a hone in and out of the bores a couple times to break any glaze and help the new rings seat
ANTICOP RAM AIR
04-22-2012, 12:17 AM
do a compression/leak down check... if its still within spec and held good pressure, Id run it as is...
MY_2K_Z
04-22-2012, 02:47 AM
ya im definatley going to hone it. still cant believe the condition of it. my friend bought an lq4 from a junk yard and it only had 80000 and it was in terrible shape on the inside. i plan to do a stock bottom end and a front mount turbo
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
