rgarner~z28
04-21-2012, 11:43 PM
i just bought a 2000 z28 when you drive it right it shifts fine when you get on it dont want take 2nd gear and grinds when you go to 4th
rgarner~z28
04-22-2012, 03:51 PM
anyone maybe slave cylinder?
thesource
04-22-2012, 07:16 PM
Could be a bad pilot bearing, bad 4th gear syncro, bad slave cylinder for maybe the shifter stop has worked loose if its an after market shifter.
rgarner~z28
04-22-2012, 08:05 PM
it is stock shifter and i can change gears with out the clutch with no grinding so dont think its syncro
